1957 Oldsmobile J2
1957 Oldsmobile J2
Hello:
My '57 Olds 98 has a single 4 barrel, and I recently acquired an air cleaner and a tri power set up for it. Problem is the throttle linkage. It appears to be set up the same, only shorter on the tri power. Should I just shorten the linkage from the 4 barrel?
Eric in Ohio makes the J-2 stuff...440- 842- 2802 ericsolds@sbcglobal.net
If the threaded rod doesn't have enough adjustment to shorten the rod itself, you could 'chase' the current threads with a threading die, and cut them 1-2" deeper for more adjustment.
Buy the tools @ Sears, and return them, CLEAN, when done - kinda sleazy, but cost effective!
simmynole
January 26th, 2008 04:33 AM
