What's up with the PNC ads?
The PNC ads (blue rectangles) which pop up at the top of the page whenever I move to a new forum are infuriating. They lock up my screen and prevent the forum from ever appearing -- leaving me staring at nothing but their ad (which I'm sure is their intent). None of the other advertisers cause this problem.
The only way I've found to get around this is to hit the back button, then the forum link again, then the back button, then the forum link one more time (third time's the charm, I guess), after which the list of threads for the new forum appears. Given the slow refresh times on this site, it takes about a minute for me to switch forums.
Does anyone else have a problem with this? Any suggestions on a better way to get around it?
If that's just the way it works for everyone, then I suggest the owner of this site eliminate the PNC ads. They can't possibly be worth the money. I'm considering not frequenting this site anymore, because I've got better ways to spend my time than clicking the same buttons over and over. The ads certainly aren't serving their intended purpose, as I'd never chose to do business with a company which intentionally sets out to annoy me.
You must mean the ones that follow you as you scroll down, covering the page. I kill the page and start over (yep, waste of time.) I dislike the bingers but at least scrolling down makes them disappear.
Best prevention is to watch where your mouse is going (or disable java for this site).
Keep your mouse off the main text and you are somewhat safe. The green underlined stuff triggers these things.
Java can play havoc with many machines (regardless of version), meaning all machines in my experience. Flash is worse IMO, so i keep it disabled unless I really need it.
The only useful related ads on this site that I have seen would be the tirerack ones at the top...
I wonder how many people actually purchase anything from these absolutely positively annoying popups? I wont just because of the annoyance! Lawyer adds are next! yeay! Cuz everyone needs one.
X again!
I installed both of the above in 2012 or before when this site would no longer work with IE6. I was using Intermute with EI which killed most ads.
Firefox and Adblock were two God-sends that saved the internet for me!
No ads at all. If you install Adblock nowdays, you have to remove a checkmark in a box in setup that allows "non-intrusive ads" like text ads.
I'm lovin it!
I'm lovin it!
Mark - Another guy on this site who will remain nameless, although he has a PINK Delta 88 vert, and his name rhymes with MDchanic, tells me that Apple products aren't affected by this kind of pop up. He must have an advanced model.
Adblock Plus can be downloaded for apple products too.
I dunno whom you're talking about, Allan, but my Mac is never afflicted by these demons.
I use Chrome (usually) with AdBlockPlus, but also Safari, Firefox, and Opera sometimes, and never have a problem with any of them.
Perhaps Mark is using that copy of Explorer 5.2.3 that was on that AOL CD he found in the disk drive?
No, I mean that's the latest version of Explorer for Mac OS X that I'm aware of, and it's a version from 2003.
Updating to the latest browser versions is always a good first step toward blocking out unwanted junk, no matter what platform one is using.
I know that the tech team of our parent company is working on this issue, so hopefully we'll have some relief soon. In the mean time, Adblocker Plus and Chrome or Firefox browser = ZERO ads.
Still getting these annoying PNC ads when the mouse hovers or glides over the blue underlined words! This is as annoying as an exwife! Was fine for a year now back right back to it! Any new suggestions? TX!
I surf in peace.
If you or someone who uses your computer has had a problem and had to disable it to down load a file or do a fix something may have caused you to loose Add Blocker, you may need to re install it ....From the keys of Tedd Thompson who knows almost nothing about computer programs... Disclaimer...Tedd
goodkarmech
December 2nd, 2010 03:10 PM
