picture posting
picture posting
Can someone post the procedure to add photos to an ad? I cannot seem to post pictures , and the one I did get done was quite the accident and I cannot figure it out .
Post #2 contained in https://classicoldsmobile.com/forums...-pictures.html is no longer valid.
The sticky @ https://classicoldsmobile.com/forums...-pictures.html needs to be updated with the current information as contained in the following image:
You're wrong. (1) The updated photo icon has the sun on the right-hand side; (2) The current updated image has no Fonts; (3) No ability to change Sizes; (4) No availability to change color; (5) The link icon is different, etc., etc. - not to mention (again) the updated image is the current image and not the same as the previously posted image.
Yeah, I mis-typed right-hand instead of left-hand. He and yourself are both incorrect. The picture you posted is the EXACT SAME IMAGE as the image I posted. The image contained on Post #2 @ https://classicoldsmobile.com/forums...-pictures.html is not the current updated image.
I'm trying to provide end-users with the most updated and correct image they will view. The orientation of the icons and availability of active elements is entirely different.
Additionally, Post #3 @ https://classicoldsmobile.com/forums...-pictures.html should contain the most updated image to enhance the end-user experience to ensure they see exactly what we expect them to see.
Outdated Image
Updated Image
Outdated Image
Updated Image
Yes, there is now the availability of strike-through and color option. Those two simple active element options were not available when I joined the site in July I can attest that as fact. Those are recently enabled active-elements.
I think no matter how you do it if the actual picture size in mbs is smaller like kbs you'll have better luck. I think many times when people says their efforts are hit or miss I think it's related to size and connection speed.
for images that don't require great detail I resize to 1024x768. Or 800x600. That typically will take a 4 mb image to ~300kbs.
end result is 80% of the time it works every time!
When it comes time to 'render' the image (make it viewable to an end-user) - much has to do with the rendering software; and, here is where many websites differ (but, also PCs, cameras, phones, video projectors, etc.) - but, let's stick to websites. Does the website support .png, .jpg, .jpeg, .tiff, .bmp, .bat, etc. And, each type of image is rendered differently because the back-end website software operates specifically to render each type of format differently. Add to this, the compression routines you apply to images is not going to compress each type of image file format the same as any other image file format. So, there are a couple/several scenarios involved when it comes time to rendering images. I promise not to go onto a further expose here.
One final coup de grāce. This is a free website, it does some things very, very well - in particular, the extraordinarily rapid indexing of topics, threads, and posts on very fast back-end servers. There are some things which are not enabled on the back-end of this website which could further enhance end-user experience, but I'm not even going there. Let me just say this. Extraordinarily top-end social media websites (and many websites which contain hundreds of thousands>hundreds of millions>hundreds of billions) images run image compression software on the back-end which the end-user never sees. There are no size limits to the image upload and for some websites, there is no size limit to video uploads. Those are NOT free websites. But, the compression routine runs on the back-end so end-users don't even need be concerned.
.JPEG and .JPG are the two most highly recommended image file formats for uploading and rendering onto (in particular free) websites.
