Deleting a "nonexistent" photo album
Something hinky happened the first time I tried to create a photo album [named '89 Olds Custom Cruiser "Angie"], so I created another, which worked perfectly.
I therefore went to delete the first, but found that when I tried even just to access it, it gave a "page not found" error, period.
Is there a way on your end to delete it? Leaving it there isn't hurting anything, but it is annoying when people want to see my images and get that "blank" page instead.
Thanks either way,
Drew
Thanks either way,
Drew
Got it fixed, but it took me some doing. All gone now. Problem was with the single ' and double " quotation marks you used in the title, which confused the forum software. If you avoid using those in the future the problem probably won't reoccur.
https://classicoldsmobile.com/forums...junqueboi.html
81 regency
April 21st, 2011 06:18 PM
