Toro oil pump
Here's the two side by side. The Toronado pump is on the left. The pickup is in a little different location and it may hang a little lower, but I'm not sure if its really lower or not. Joe, if someone uses the Toro pan without changing the sump do you think it will make a big difference? John
Sorry to resurrect this old thread, but are the pickups interchangeable? Looking at a high volume pump that has the RWD pickup on it, and want to put it in my Toro 455. In other words, can I pull the pickup off my stock pump and put it on the aftermarket pump?
