Where do these go?
Old March 23rd, 2017, 05:54 AM
m371961's Avatar
Where do these go?
Working on interior. Dug these out in the parts that came with the car and cannot figure out or find where they belong. There are 2 similar aluminum parts that mount to the front lower seat frame.
m371961 is offline
Old March 23rd, 2017, 05:58 AM
Oops...
There is also trim that goes on the back of the seat on either side. If you post a pic of all of the trim we can help you figure out what goes where.
Olds64 is offline
Old March 23rd, 2017, 06:42 AM
m371961's Avatar
Ok, I will do that, the other pair goes on the lower frame and wrap around it on the front. Do these go on the seat back, vertically on the door side?
m371961 is offline
Old March 23rd, 2017, 06:49 AM
Correct. Here's a picture of a 63, but you get the idea.
Olds64 is offline
Old March 23rd, 2017, 07:20 AM
m371961's Avatar
Thank you very much.
The other question is mounting? I find no info in factory manuals, is there a PIM for Fisher stuff?
One of the lowers has a bracket or piece of one. Did not figure on the gap between the 2 being so close.
Very cool look they give.
Gotta remind my self to use the resources of sales info.
m371961 is offline
Old March 23rd, 2017, 07:37 AM
The top one in your picture has two holes in it for pan head sheet metal screws. I'm not sure how the bracket works. All of the ones in my 71 98 use sheet metal screws.
If your interior has been redone it might be hard to find the holes in the seat frame under the upholstery for the sheet metal screws. I suggest using a small needle or awl to poke the upholstery until you find the hole. If all else fails you can use double sided emblem tape to secure them to the seat. Tacky; I know, but it will get the job done in a pinch
Olds64 is offline
Old March 23rd, 2017, 08:37 AM
m371961's Avatar
I'm working on the frames now, got distracted and thought I better check how these fit and mount before I go to messin with the upholstery.
m371961 is offline
Old March 23rd, 2017, 09:14 AM
Shows us pics of the seats when you finish. I bet they will be awesome!
Olds64 is offline
Old March 23rd, 2017, 11:21 AM
m371961's Avatar
I ain't searching for perfection. I only expect perfection when I have to pay someone to do it. I am looking for adequate and decent for the money I put in it. The whole car will only look like a rebuilt car with some miles already on it.
m371961 is offline
mikebass2112
January 8th, 2008 08:17 PM
77supreme
March 12th, 2007 03:42 PM
Deltarocket
February 5th, 2007 05:00 PM
jaco
January 26th, 2007 07:57 AM
fnfship
March 11th, 2005 09:12 AM
Quick Reply: Where do these go?
