Spark Plug Color
Speaking of plug color, these are from a 30mn trip mostly freeway. Pulled not to long after I got home.
I had a pretty bad lean surge but was less noticeable on the freeway. This is with 67 jets, I went to 69 and it seems to be gone but I feel like I can still hear it in the exhaust
The problem with spark plug color is it has to be done immediately. You can't take an extended trip with a new set of plugs and get a good reading.
Easy way to do it is to put in a new set and take a 1/4 mile blast right away. Ideally you can shut the engine off at the end of the run and coast to a stop. Now remove a plug and look at it.
Honestly your plugs don't look bad and I'm not understanding the lean surge. At least by the way the plugs look
