Racing Calculator Thread - ClassicOldsmobile.com
Old August 9th, 2015, 12:31 PM
This thread is for calculators, here's a link I use often. Please add calculators that you find helpful.
http://www.wallaceracing.com/Calculators.htm
wr1970 is offline
Old February 6th, 2016, 04:36 AM
car nut farmer
71rocket's Avatar
Cool, thanks
71rocket is offline
Old March 15th, 2017, 02:58 PM
74sprint's Avatar
Olds BB combustion chamber measurements
For the life of me I could not find measurements of the Olds BB combustion chambers. Almost all of the BBO combustion chambers are the same size and are 80cc. These drawings are of the actual stock 'G' & 'J' heads but, the distance between the valves is the same for all heads big and small. The distance between valves is 2.0" which is also the distance between rocker bolts/studs and push rods. Pontiacs also have a 2.0" spacing so you can use Pontiac guide plates, even the stock ones, just cut the 2 cylinders apart, the plates do 2 cylinders. The 'J' heads distance varies a lot, from 1.987" to 2.010" all on the same head, wow. The combustion chamber with the larger valves is for my new build. Any questions pm me and I'll try to answer them.
Ray
File Type: rar
74sprint is offline
twinjracing
August 29th, 2014 07:42 PM
Nilsson
February 14th, 2014 02:51 PM
aquabird
April 28th, 2013 11:04 PM
zipper66
February 13th, 2013 05:34 PM
cutlasssupreme71
Wheels and Tires
December 2nd, 2009 03:31 PM
Quick Reply: Racing Calculator Thread
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
