Help getting engine tuned up for optimum performance
#42
I made a limiter plate to limit my vacuum advance and found mine does not even work and was just acting as a vacuum leak. I swapped in a functioning one but have not tested it. I'm also working on getting the 650 cleaned out so I can try it again.
#43
Got a photo of this? Isn't that usually a screw mounted to a steel plate? How would it cause a vacuum leak?
#45
I got the engine running really good. I got some help from cliff Ruggles and set up a sweet quadrajet off a 69 tornado I saved a few years back. Anyway with the addition of a 1" tapered spacer and some parts from cliff it's like a whole new engine! Just my luck it took me this long and now I have to wait until next season to get to the strip.
#46
#47
So far it runs like a dream compared to all the Holley style carbs I had on. I actually am very biased towards quadrajets but when I originally put this one on it had a pretty bad lean surge so I cast it aside. After all the fuss with Holley style carbs I decided it was Time to talk to cliff and get back to a quadrajet. I know holleys can run great but I believe in quadrajets for all aplications that are within there limits. Thanks and same to you
#48
Trying to get my new combo dialed in. Changed the cam to .540 lift 227 duration single pattern, turbocharger, meth injection. I took the power piston out of the qjet and went with .065 main jets but left the sencondaries how they were. Finally got my wideband hooked up today and I'm going really lean under boost. I'm 12-13 afr cruising, depending on gear and rpm. But under boost I saw it go as lean as 16, dialing in the meth got me into the mid 15's. I'm hoping a simple secondary rod change will richen it up but any one have an idea of how much to richen it up( which secondary rod to try)?
#49
Trying to get my new combo dialed in. Changed the cam to .540 lift 227 duration single pattern, turbocharger, meth injection. I took the power piston out of the qjet and went with .065 main jets but left the sencondaries how they were. Finally got my wideband hooked up today and I'm going really lean under boost. I'm 12-13 afr cruising, that's because you don't have the power piston in it, it should be around 14.0:1 at cruise depending on gear and rpm. But under boost I saw it go as lean as 16, dialing in the meth got me into the mid 15's. you need to be in the 12.0:1 range there I'm hoping a simple secondary rod change will richen it up but any one have an idea of how much to richen it up( which secondary rod to try)?
#52
Yeah, that's why I'm going for the change. I drive it to much to fool around with a carb. I'm going to work with cliff Ruggles some more with the qjet and hopefully get it set up right. He says a single qjet can support up to 700hp
Napoleon Solo
February 14th, 2012 09:43 AM
wmachine
December 30th, 2009 05:55 AM
