455 roller cam
Old July 7th, 2015, 06:31 PM
jimmymtfan19's Avatar
455 roller cam
Want to run a roller cam. Does it make much more power than a flat tappet?. Was thinking comp 283thr7 cam. What's best way to find correct pushrod length with this combo.
jimmymtfan19 is offline
Old July 8th, 2015, 01:18 AM
motorhead_1's Avatar
i suggest a proper pushrod tool. can be had for about 20 bux.
you tube vid here as well,
motorhead_1 is offline
Old July 8th, 2015, 04:34 AM
cutlassefi's Avatar
Get a cam that's right for your combo, not one that just makes noise.
cutlassefi is offline
Old July 8th, 2015, 12:32 PM
real57vetteguy's Avatar
Cutlassefi is 100% correct. Years ago I stopped buying "Box Shelf" cams when I realized those cams are just a generic grind that will work OK with several different engine combinations.
There is power to be gained by grinding a cam for your specific needs/desires/combination.
I have used Mark (Cutlassefi) for more than one custom grind and been overly happy with the results. I see plenty of engines with the almost identical build as mine making much less power and the only big difference I can see is a lot of them are running a box cam VS a custom grind.
real57vetteguy is offline
Uncle Hulka
March 12th, 2014 03:41 PM
dfire25
February 26th, 2013 07:36 AM
sethj78
May 1st, 2012 10:48 AM
Redog
August 14th, 2008 06:56 PM
72RocketPower
August 11th, 2005 04:51 AM
Quick Reply: 455 roller cam
