Ring Gap ?
Old October 7th, 2013, 11:55 AM
11.52 @116
jims2000lt's Avatar
Ring Gap ?
Just got my block and crank back from the machine shop. I'm about to start assembly of the short block.
Where should I set the piston ring end gap?
Its a 60 over 455 that is going together with an Eagle rotating kit. Cast crank, H-beam rods, SRP flat top pistons, Speed pro moly rings.
Block was line honed, zero decked, bored over then honed with torque plates, hard block filled to the water pump holes, and crank was balanced.
Having my E-brocks checked and rebuilt if needed and installing RPM performer intake.
Plans are for a HYD Roller which I will need new valve springs for.
jims2000lt is offline
Old October 8th, 2013, 09:15 AM
TripDeuces's Avatar
http://www.dssracing.com/v/vspfiles/...structions.pdf
This info should have come with the rings.
TripDeuces is offline
Old October 8th, 2013, 12:33 PM
captjim's Avatar
A good rule of thumb is .0045 per inch of bore. So, a .030 over 455 is 4.185 x .0045 = .0188325 or basically .019
captjim is offline
Old October 8th, 2013, 01:10 PM
cutlassefi's Avatar
I normally shoot for .020 on the top ring and .015 or so on the second ring.
You must have good fuel, you'll have about 11.0:1 with the SRP's.
cutlassefi is offline
Old October 10th, 2013, 07:56 AM
11.52 @116
jims2000lt's Avatar
Thanks guys.
wabasto
December 23rd, 2015 01:09 PM
orange442
July 9th, 2015 04:32 PM
oldspackrat
August 10th, 2014 10:03 PM
dman0712
April 13th, 2010 06:38 PM
The_Jeremiah
December 7th, 2007 08:06 PM
Quick Reply: Ring Gap ?
