Rear Suspension Setup for a Weekend Warrior?
Old July 11th, 2013, 04:49 PM
TheBigBlueBoat's Avatar
I'm looking to at least get an idea of what parts to use to rebuild the rear suspension.
The car will be built with the intention of being a weekend warrior, that is to say I could cruise it during the week, then fill up the bottle and slap on the slicks'n'skinnies for a weekend night at the track.
The drivetrain won't be terribly aggressive; 350, high compression, ported heads, moderate cam, mid-RPM intake, bigger carb, stalled auto, with a moderate shot of spray. I would also like to be able to launch on slicks.
So what parts would be necessary/desirable for such a setup?
Axles: I'm guessing 31 spline would be a good idea based on the slicks and stall. Right now it's got stock axles with a 3.73 posi rear end.
Diff Cover: Is this necessary? If so, do I need a W27 brace, or something like an LPW cover with girdle? I highly doubt that a cover with full tube brace would be necessary.
UCA/LCA: I know poly bushings all around are necessary. Do I need fully boxed or other aftermarket pieces? Do the mounting points need to be reinforced? Are adjustables a must?
And last, are there any other traction aids that would be useful?
Any thoughts or advice are welcome. I'm a bit rusty on the old SRAs since going to the dark side of an IRS. Of course the remedy for those not chattering the teeth out of your head with wheel hop and slinging axles everywhere was Delrin/aluminum bushings everywhere, 31 splines and a heavy duty diff cover.
TheBigBlueBoat is offline
Old July 11th, 2013, 05:15 PM
TripDeuces's Avatar
Your first launch will tell you a lot.
I would do air bags and boxed arms at the least. Poly bushings next and then work from there. No need for the exotic stuff until you do serious track time. Air bags will make a world of difference for traction as will no hop bars. If you go that route start with 15#'s on the right and 5#'s on the left. Adjust the right bag up or down until she comes out dead straight in the bleach box.
TripDeuces is offline
Old July 13th, 2013, 06:16 PM
Boxed arms and poly will be a definite, and I think I might opt for the no hop bars.
I've never dabbled in air bags yet so I'm not too sure on that just yet.
Thanks for the tips.
Old July 14th, 2013, 05:57 PM
64Rocket's Avatar
I would go with the poly bushings all around. And of course the lower box arms, or one of the after market lower arm assy.
you must have a chubby 12 bolt rear in order to have 3.73's What you have now will work fine for now. As you work your way to more power and faster times , you can up grade as you go. Once you have a bunch of seat time, you will get a feel for what will improve your performance.
God luck.
Gene
64Rocket is online now
Old July 16th, 2013, 09:15 AM
chadman's Avatar
Here is what I have on mine:
UMI boxed LCA's with poly bushings
UMI tubular adjustable UCA's with poly bushings
UMI tubular mount braces
BMR anti-roll bar
12 bolt Chevy w/33 spline Moser axles and weld on housing ends for 9" Ford bearings
T/A Performance support cover
33 spline posi unit w/steel clutches
chadman is offline
redoldsman
September 8th, 2014 08:59 AM
67 Olds 442
Wheels and Tires
16
February 8th, 2013 02:51 PM
COcutlass72
May 6th, 2011 09:26 PM
J-(Chicago)
March 5th, 2008 02:07 AM
Quick Reply: Rear Suspension Setup for a Weekend Warrior?
