BBO heads
Old June 20th, 2013, 07:20 PM
brandon 455's Avatar
BBO heads
I currently have c heads on my 455. I was looking for some aluminum heads and I run across the procomp brand. Has anyone run these, or would the edelbrocks be a better choice?
brandon 455 is offline
Old June 21st, 2013, 08:19 AM
cutlassefi's Avatar
Procomps are fine. If you looking for the last little bit of hp then the Edelbrock may be better as they have a different combustion chamber.
But either way they're both waaaay better than stock irons. I'd do the Procomps in a minute. Contact Bernard Mondello in Ca, he'll set you up right.
cutlassefi is offline
Old June 21st, 2013, 10:30 AM
380 Racer's Avatar
So Mark, the Pro Comps started out as a SB head? Was that because of the fuel pump fitting. Chambers? Are they big for a SB or small for a BB? Just curious.
380 Racer is offline
Old June 21st, 2013, 01:32 PM
Okay thanks for the reply. The price difference is what was kinda scaring me about them. I was always told you get what you pay for and I didn't wanna buy a set of heads and they be no good.
Old June 21st, 2013, 02:11 PM
cutlassefi's Avatar
No same as the original Edelbrocks. They were designed for a big block first but will work on a small block with the right combo and electric pump.
Old June 21st, 2013, 03:14 PM
380 Racer's Avatar
So they still need an electric pump also. (wouldn't bother me at all) OK thanks.
QS442
August 12th, 2014 05:56 PM
Al2011
August 8th, 2011 01:41 PM
geckonz08
November 1st, 2009 06:03 AM
442_rocket
July 19th, 2008 08:43 PM
GoldOlds
November 16th, 2007 05:56 PM
Quick Reply: BBO heads
