Pedestall for Harland Sharp #5001?
Old June 14th, 2013, 10:06 AM
joepenoso's Avatar
I've got a 455 Olds.............#5001 Harland Sharp Roller rockers......ARP Rocker stud installation or pedestal #134-7104(7/16-14tpi base that fits into the head and a 3/8" by 24 tpi that is too small to fit in the Harland Sharp hexhead lock nut. What ARP pedestal/ Rocker installation stud do I need???
Harland Sharp is closed Friday 11:00AM until Monday morning EST.
joepenoso
joepenoso is offline
Old June 14th, 2013, 10:20 AM
joepenoso
Not really rocket science here. If you google "5001 Harland Sharp roller rockers" you get this:
Originally Posted by Jegs
Harland Sharp#851-5001
Aluminum Roller Rocker Arm
Oldsmobile 350-455
1.6 Ratio
7/16" Stud
Set - 16/pkg
Sounds like you need a stud that's 7/16" on both TOP and bottom. Should be about a million sources of those.
joe_padavano is offline
Old June 14th, 2013, 11:47 AM
joepenoso's Avatar
Lightbulb
Thanks for your time and speedy responce...........
"Sounds like you need a stud that's 7/16" on both TOP and bottom. Should be about a million sources of those. "
You're right there are 19 different pedestal rocker studs 7/16" inch top and bottom at ARP alone. All of them or some of them might fit and work with Harland Sharp roller rockers # 5001...I wonder which one???
joepenoso
Old June 14th, 2013, 12:12 PM
joepenoso
The problem is that the exact length will depend on your engine's specific valvetrain geometry, pushrod length, and how much the heads have been cut. That's why studs are available in roughly 0.10" length increments. With the lifter on the base circle, set the rocker on the pushrod and valve tip and measure the distance from the top of the guide plate to the top of the rocker pivot shaft. Add to that the depth inside the polylock with the lock screw at about the middle of travel. That's how much effective stud length you need. The reality is that there's probably enough adjustment in the polylock that you aren't that sensitive to stud length.
Old June 14th, 2013, 05:33 PM
joepenoso's Avatar
Assuming stock length valves......................9.8 inch pushrods................uncut heads.................7/16" UNC. bottom and 7/16 UNF. top thread where does that leave us with just "ARP rocker stud installation bolts" ......................
see ......................
non rocket science isn't that easy
thanks
joepenoso
f-85
March 29th, 2013 12:51 PM
bosch 68 442
June 29th, 2011 05:02 PM
oldzy
June 1st, 2011 08:30 PM
70OLDS442
November 21st, 2007 05:00 PM
Quick Reply: Pedestall for Harland Sharp #5001?
