Need Input- 1/4 Mile & Trap Speed
Old April 16th, 2019, 07:27 PM
Chris6542's Avatar
Need opinions. Building a 67 Olds w/455. What 1/4 mile time & trap speed is reasonable for this build: 3200lbs (lightened), 440hp 468ci (.060 over), built 200R4 (steeper 1st gear, OD, etc), 3.55 axle w/Eaton posi, and a set of Mickey Thompson Sportsmans (L60s rear and 225/70 front)? What 1/4 time & trap speed should this combo be able to attain?
Chris6542 is offline
Old April 16th, 2019, 08:21 PM
VORTECPRO's Avatar
440 crank shaft HP has the potential to run 121.5 MPH @ 3200 pounds. 1320/121.5=10.86 ET. Now the question is: will the OD trans let you reach that potential, I don't think so, but the results will be interesting. I will say high 11s to 12s.
VORTECPRO is offline
Old April 17th, 2019, 08:20 AM
Chris6542's Avatar
Old April 17th, 2019, 09:02 AM
Chris6542's Avatar
Thanks for the thoughts Vortecpro. I was thinking low 12s @ perhaps 110mph. I'll report once running and dialed in. Thanks again.
Old April 17th, 2019, 08:19 PM
Chevy budget Olds powered
coppercutlass's Avatar
HMMMM the big question is how efficiently can you put the power down. I ran 12.20's with about 360 HP from a 355 olds and I know I was leaving some on the table but the 360 HP was based off of the 1/4 mile trap speed and weight. Hit the track and get some base numbers.
coppercutlass is offline
Old April 18th, 2019, 07:58 AM
GEARMAN69's Avatar
Easy 12's but 11 sec potential if you can 60 foot good IMO
GEARMAN69 is offline
Old April 19th, 2019, 06:49 AM
GEARMAN69's Avatar
That sounds more the rear wheel HP to me....
Old April 19th, 2019, 05:55 PM
VORTECPRO's Avatar
Crankshaft HP.
Old April 20th, 2019, 10:00 PM
Chris6542's Avatar
Great Input
Thanks to all for the great input, I expect it to run well. I would be pleased with perhaps a 12.2 @ 110. Though Im sure it wont stop there. Thanks again to all.
Old December 20th, 2019, 03:17 PM
JLawrence's Avatar
Been a couple years but watch Kost run low 11's at something like 113mph
JLawrence is offline
Old December 20th, 2019, 03:29 PM
oldsmobiledave's Avatar
440 crankshaft hp in a 3200 pound car will run 11.87 @ 120.75 mph at sea level.
Use this link for estimates.
https://robrobinette.com/et.htm
oldsmobiledave is offline
wayne3791
December 25th, 2015 06:51 AM
1968ragtop
45
March 27th, 2015 05:43 PM
STLCRZY
Drivetrain/Differentials
May 4th, 2014 12:49 PM
Railguy
October 13th, 2013 07:20 AM
442much
March 14th, 2010 12:53 PM
Quick Reply: Need Input- 1/4 Mile & Trap Speed
