J heads... dead horse!
#81
I have never over cammed an engine. The only reason i asked is because back in the stocker days head modifications where limited and many ran "cheater cams" i belive they had to measure at OE specs so i assume the ramp profiles where changed to help the heads flow better by . Just from what i know atleast.
#82
I think it is only human for a person to think that bigger is better. Myself, when I build an engine I always have to fight the urge to use a large cam that sounds good (because thats what the customer wants) and use a cam that has good drive-ability(because thats what the customer really wants). They just don't know it!
#83
i have never over cammed an engine. The only reason i asked is because back in the stocker days head modifications where limited and many ran "cheater cams" i belive they had to measure at oe specs so i assume the ramp profiles where changed to help the heads flow better by . Just from what i know atleast.
#84
My 455 project will be just a budget hand me down build . thw J heads im running have been proven to work to atleast 11.50's so should work for me .Most wouldnt bother running them as they think they are junk
#85
Stock 'G' head flow
I've always said ported 'J' heads flow just as good as stock small valve 'G' heads, so why bother with 'J' heads. Ported 'J' heads N/A will get you about 400 shaft Hp which is good for the street but I would not pay someone to port them period. I had my stock 'G' heads flowed and the results are:
Stock 2" intake, 1.62" Exhaust at 10"
You can find a very good listing of cylinder heads at Stan Weiss Web Site, my heads are the ones listed as 'Olds G Iron', he only took the info he wanted and he converted the 10" to 28" but I get a little more flow when converting to 28", 232 cfm on intake. One more thing I think is important is converting air flow to Hp at Air Flow to Hp. I am in the slow process of porting my 'G' heads as I find time and will be going with 2.15'/1.68" valves and twin 70mm turbos but, I have stock small valve 'G's on right now. I hope this helps.
Ray
Ray
#86
Stock C heads with back-cut 2.00 valve 1.678 exhaust valve
.50 29 na
.100 66 59
.150 101 83
.200 133 105
.250 156 121
.300 171 131
.350 187 141
.400 199 150
.450 208 157
.500 215 161
.550 222 165
J heads 2.07 valve tricky port work
.50 37
.100 69
.150 110
.200 148
.250 179
.300 205
.350 221
.400 227
.450 229
.500 231
.550 232
Same flow bench, same day, same operator. I also have a set of stock G heads. The C heads that I have listed here flow more than the G heads. My ported J heads will stomp a greasy mud hole in both of them in stock form. This i kinda what I found out porting the J heads. They are tricky.
.50 29 na
.100 66 59
.150 101 83
.200 133 105
.250 156 121
.300 171 131
.350 187 141
.400 199 150
.450 208 157
.500 215 161
.550 222 165
.50 37
.100 69
.150 110
.200 148
.250 179
.300 205
.350 221
.400 227
.450 229
.500 231
.550 232
#87
Yep, your ported J heads are really great at low to mid lifts and they hang on at the .550 numbers also.
With that much much difference in the numbers, those J’s would be putting out a lot more power than the C’s for sure!
#88
Thank you. I am convinced that I can get the same results from an Olds small block head. I just need a willing participant.
#91
My ported J heads have 169 cc on the intake ports. The C head that I listed the flow numbers from has 182 on the intake port. Just because, I checked the port volume on a #6 head that I have here, it was 155 cc. For anyone that would be interested I checked the port on a set of Pontiac 6X heads that I am building, they are 164 cc ported. Pontiac heads,,,, now there is another challenge!
#92
Boo Pontiac, Boo!
haha.....
Ok, so, since you have a dyno..... I vote for a stock J head chassis dyno test vs a ported J head dyno test vs. a stock c head dyno test vs. a ported C head dyno test. If you use Cometic gaskets, and you don't silicone the intake gaskets, it would be an easy and clean swap.... not like you aren't capable and you don't have a nice car to play with now!!!
haha.....
