Edelbrock total power package or just heads - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Repair & Restoration > Racing and High Performance
Edelbrock total power package or just heads >
Old November 12th, 2018, 03:59 PM
oldsdriver1218's Avatar
I was thinking of upgrading the top end of my 455 found this setup on Edelbrocks web site I was wondering if anyone has used this kit and if so what you thought about it If so what rockers did you use Or if anyone has used just the Edelbrock heads witch rockers did you choose and are you happy with the there are a lot of choices Scorpion Comp cams offers a few choices Harland Sharp I'm sure the list goes on just looking for a little input so I can make an educated choice
oldsdriver1218 is offline
Old November 12th, 2018, 05:31 PM
Iím running Harlan sharp rockers on my Edelbrock heads. I havenít seen a Edelbrock catalog in years, so I donít know if they have updated the Olds line of camshafts. Since itís not chebby, Iím guessing the list is still pretty small! The camshaft thru recommend is pretty puny and outdated, you can find much better options today. Call any reputable cam company (or talk to Mark on this forum) they can either suggest a cam or custom grind one.
matt69olds is offline
Old November 12th, 2018, 07:59 PM
thanks any info is helpfull
Old November 13th, 2018, 05:24 PM
I've been looking at many different cams and I noticed that mondelo offers a cam with the same specs
Old November 13th, 2018, 06:09 PM
Hmm not really.
Let me explain. The Edelbrock flat tappet cams are very generic grinds, unfortunately somewhat lazy.
Conversely the Mondello cams are done by Engle and can be a bit noisy depending on the grind.
That Edelbrock top end kit is a decent deal, except for the cam, again an old grind.
What power level at you shooting for? Maybe I can help, Iíve posted lots of builds and combos on here.
Let me know. Thanks.
cutlassefi is offline
Old November 13th, 2018, 07:44 PM
I talked to the owner of engle this past july, he does still grind and sell the old joe mondello grinds but the ones lynn mondildo sells are not his they are,,,,, wait for it,,,,,, from china.
315442 is offline
Old November 14th, 2018, 05:28 AM
olds 307 and 403's Avatar
That would explain the white boxes. I wonder if they actually measure anywhere close to what they should.
olds 307 and 403 is offline
Old November 14th, 2018, 02:19 PM
i find this very difficult to believe! Surely Lynn wouldnít skimp on quality just to save a buck?!
Of course he would!!
Old November 14th, 2018, 04:05 PM
Originally Posted by cutlassefi View Post
Hmm not really.
What power level at you shooting for? Maybe I can help, I’ve posted lots of builds and combos on here.
Let me know. Thanks
My 455 is 40 over has 10 to 1 compression I would like to make 1 H P per cubic inch the Edelbrock package says 450 H P at 9 to 1 with the package I am no cam expert that's why I'm asking questions I want to stay with a hydraulic cam non roller its not a race car any help will be appreciated its more a weekend warrior and cruse night car but you got to sound as good as you look I only looked at mondello to compare grinds never planned on buying from them. thanks for your help
Old November 14th, 2018, 08:33 PM
Once Olds Always Olds
Troys Toy 70's Avatar
Talk to Mark, cutlassefi. You wonít be disappointed.
Troys Toy 70 is offline
Old November 15th, 2018, 03:59 PM
do you have a cam recommendation and if you do can you tell me what I can expect from it thanks
Old November 15th, 2018, 05:49 PM
Compression? Gear? Trans? Intake? Carb?
Old November 15th, 2018, 06:02 PM
compression 10 to 1 gear is 373 turbo 350 2500 stall converter Edelbrock torker carter competition 750 block is 40 over
Old November 15th, 2018, 06:04 PM
will be adding Edelbrock aluminum heads also already has Mallory comp 9000 distributor with cd box
Old November 15th, 2018, 11:41 PM
Chevy budget Olds powered
coppercutlass's Avatar
Just as an observation cutlassefi called the engle cams noisy . define noisy. I ran the voodoo lunati cam which in the past he claimed noisy and was super quiet for me. I now run a solid flat tappet cam and is quiet. Just curious what noisy means because . My solid cam is really quiet. little to no valve train noise. My voodoo was also very quiet and I ran it at .010 preload and it was very quiet.
coppercutlass is offline
Old November 17th, 2018, 05:14 AM
Iíve had many different cams, rockers and such in front of me. When I say noisy I mean ďsewing machine likeĒ.
When you say ďlittle to noĒ noise, is it a little, or none? You either hear it or you donít. Just like youíre either pregnant or not, thereís no in-between
The smaller Voodoo grinds are normally ok, just like the smaller Engle/Mondello grinds. But the larger you get typically the noisier they are. Sorry if I didnít make that distinction.
Op- hydraulic is hydraulic whether or not itís a flat tappet or roller. And you can have a mild roller just the same way you can have a ďraceĒ flat tappet.
If youíre eventually going to switch heads then Iíd do a 236/[email protected] with .565 lift on both. That would make best use of those heads.
Old November 17th, 2018, 08:13 AM
Valvetrain can make other very minor subtle operational noises which wont sound like a sewing machine so little to none is dependant on what you can hear. Although the term a little pregnant is funny .,noise can be faint enough to not be there but be there. Kinda like detonation just because it cant be heard does not mean its not there. So when I say little to none im hearing very very subtle operational noises. Stock valvetrain on these cars was pretty quiet but you can hear it operate to an extent and its not like a sewing machine.
Old December 7th, 2018, 10:04 AM
who makes the cam your recommending I get the difference between flat tappet and roller I know hydraulic is hydraulic just trying to keep the $ down so I thought I would run the flat tappet unless the price is not as far off as I thing thanks
Old December 7th, 2018, 10:12 AM
Bernhard's Avatar
Is your bottom end built to handle hp/tq uprade?
Bernhard is offline
Old December 7th, 2018, 10:28 AM
it is mostly stock has mondello straps windage tray upgraded oiling really only looking for around 450 hp don't want to go crazy again its not going to be a race car more show and weekend cruising
June 21st, 2017 06:07 AM
19cutlass71supreme
February 6th, 2014 06:28 PM
VWBeamer
March 19th, 2008 10:21 PM
Quick Reply: Edelbrock total power package or just heads
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
