Early 400 vs 455
Early 400 vs 455
I have a 400 and would like to get in the 400-500hp range. I am being told to think about going 455 because of parts are more Accessible. I am not against going with Aluminum heads route
Have seen post on here about using 455 crank in my 400 but could use some advice
The only "less accessible" parts I can think of are lifters (if it's a .921" lifter bore engine) or camshaft (if it's a 45º cam bank angle engine). Both of those are readily available through several vendors on this site, though, as are very good forged pistons.
I think it really depends upon what you want out of an engine. The 455 can make monstrous torque at moderate RPM, the 400 can rev much higher.
The 455 will allow you to reach your goal with less effort $$$ but both are capable of making 400 to 500 hp.
Pick up a copy of How to build a Max performance Oldsmobile by Bill T.
Also check out realoldspower
Edelbrock heads are a good investment. Make sure you research who to buy from and who not to, this also goes for machine shops!
There are enough horror posts to lead you to the right sources for parts and machine work.
Take your time and do your home work.
Good Luck
Good Luck
Whats the 400 going in?
Here is a link to a 400 E build
https://www.hotrod.com/articles/0906...mobile-engine/
I'm in the same situation. I have a '67 400 and a '72 455, along with a set of 12cc dish 4.057" forged pistons for the 400 and a pair of ported G heads for the 455.
And one more option: use the 400 forged crank and rods in the 455 block for a 425 cid engine. Decisions, decisions.
My thought is the 455 will give massive low end torque (maybe too much and cause traction issues?) whereas the 400 will have less torque at low RPM (for fewer traction issues) but have higher peak horsepower RPM. Kinda depends upon what your overall goals are for the car.
Definitely a possibility, but with the choice of 400, 425, and 455 cubic inches, I'm leaning towards 425 to get the same benefits of short stroke, long rod of the 400 with more displacement. Plus that would mean your new pistons for the 425 vs. the set of 400 pistons on my bench (heavy L2320F with 12cc dishes milled into them).
I would build it once and use light pistons with a modern ring pack. The Mahle piston and ring package looks like a good deal.
Are you cloning your "Cutlass convertible" into a 442? If not, someone with a non 400 B block engined true 442 will pay a decent price for the 400 engine. To make 500 hp will be a lot easier using a 455 engine as a starting point. Jmo
He said it was a 1965 442 400 so it should be a B block, one year only engine. A heads, great flowing heads but a one year only rocker pedestals. They look like there adjustable but are not. I have a set "somewhere."
In Bill's book he said they had the largest ports untouched it would be interesting to see how they flowed compared to the other big block heads.
It is a 400 B block I do still have the A heads also, it was in my sadly departed 65 442. I was just going to use it in my 65 conv to replace the non running 330, but thought I would try and get a little more hp but have been told by several that a 455 might be a better route so I bought a running one yesterday and going to work with that for now
I just dont have the 10,000- 15,000 to do a build with using the olds gurus, but am looking to start gathering parts and may build it myself which I have done before
I suspect this is due to most of the A heads not having the factory bump where the A.I.R. holes would be drilled. I know people grind those out in other heads, but with rare exceptions the A heads didn't have these bumps to begin with. So factory they would likely flow a little better than other heads.
If the 400 engine is a runner their is nothing wrong with using that as well.
The best bang for the dollars is a gear set at least 3.42
There is nothing wrong with the small block Olds 330 and good basic engine mods.
#31
If you have a running 455 you could try and build a low dollar engine using cast off parts from others.
#32
A shop named Mid-Am Performance or Mid-American Performance use to have a website with the flow numbers of the various Oldsmobile stock heads. As I recall A's were the best flowing. "If" the heads are the "bottleneck" then a plus of 5% could mean 5hp per every 100hp. Aka, 390 hp engine could turn into a 410 hp engine, hypothetically. I bought a 1965 425 (A block) twenty five years ago. It was a perfect running 4 barrel engine "except" previous owner didn't put proper amount of antifreeze and it had a crack in the block, near a freeze plug. The plug was seated perfectly. The heads were big valved and I sold the heads because I wasn't familiar with the pivot setup. As I recall the exhaust ports did not have A.I.R. bumps from the factory. That was always the first thing I use to do back then was grind them off. Anyway that's thoughts on A heads. Jmo
#33
That would be a nice increase in HP for a non modified head.
I know once you start porting the heads it maters little among the top factory heads what you started with.
#35
#36
Also what flow bench i was there many times!!!I bought some blocks and rods from him. He never had any ported heads to show me.But he was selling heads to others out of state as performance heads!! I suspect because he could take advantage of them! JMO
#37
We are going more by Bill T. His comment that in stock form un- touched, he found the A slightly better than the rest with having the largest ports.
#38
https://redirect.viglink.com/?format...2Fheadflow.htm
#39
Btw, I was just commenting on personal experience and yes, things I've read on various Oldsmobile sites over the years. The difference isn't much but they aren't all the same flow. I explained the exhaust port as I remember not having the "bumps." Imo, that would make a difference. We're talking street engines not national record holder stuff. Btw, I believe I'm in my "right mind." You seem a little worked up over my comments. I always put jmo because what I write is jmo. Hopefully the following won't get you upset.
