building a torque plate
Old March 24th, 2018, 04:50 AM
deadeyejedi's Avatar
has anyone built thier own torque plate ?if so what material and dimenssion were used .i have a nephew that works in a machine shop thats pretty handy .i ask this because in my area there isnt any olds specific builders let alone any that have torque plates for olds .it doesnt seem like it would be too hard .
deadeyejedi is offline
Old March 24th, 2018, 06:54 AM
Run to Rund's Avatar
I got the J&S a few years ago. It was economical and effective. I don't know if they are still in business (Jim Lapikas, in Iowa).
Run to Rund is offline
Old March 24th, 2018, 07:45 AM
I have looked at a couple online but they’re all over 500 dollars .run to rund if you get a chance do you think you could give me the dimensions and bore size of yours ? I could get one made for the cost of the stock .
Old March 24th, 2018, 08:49 PM
Just use a head gasket as a template.
Old March 25th, 2018, 02:05 AM
thats what i was thinking i wonder if one inch aluminum plate would be adequate ill do some more research.thanks
Old March 26th, 2018, 07:11 AM
BillK's Avatar
Most of them are made out of cast iron or aluminum. You use the cast iron one if you are using a cast iron head and aluminum for aluminum. Most of them are about 1 3/4" thick and use hardened steel spacers to make up the difference for the head bolt length.
You want the head bolt to go into the block the same amount as it does with the cylinder head. Also you should use a head gasket with the plate for the most accurate results.
BillK is offline
Old March 26th, 2018, 07:39 AM
Good info , thanks bill
olds 307 and 403
20
March 7th, 2017 02:19 PM
smcurro
January 8th, 2013 06:36 PM
Al2011
February 15th, 2012 03:57 PM
sx455raidercelticfan
November 21st, 2010 05:23 PM
Bobsw32
August 14th, 2009 07:45 PM
Quick Reply: building a torque plate
