Heat riser block off epoxy & plugs together??? - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Repair & Restoration > Racing and High Performance
Heat riser block off epoxy & plugs together??? >
Old March 5th, 2018, 01:07 AM
Bernhard's Avatar
https://www.summitracing.com/int/par...2733/overview/
These plugs ground to fit well not force fitted, then set in with epoxy.
The thought behind this is that a smaller amount of epoxy would be subjeted
to the extreme exhaust temperature.
Some of the hi heat epoxies are not designed to span a large distance.
Again this method is for those that have machined heads not bare core heads.
Another thought would be to tack weld them into place but this method is risky as you can cause warpage
even with a tack.
Bernhard is offline
Old March 5th, 2018, 09:46 AM
Here are two old threads about blocking the exhaust crossover with epoxy:
https://classicoldsmobile.com/forums...d-product.html
https://classicoldsmobile.com/forums...echniques.html
I don't think you will be able to use epoxy for this application. If you don't want to melt aluminum to fil the exhaust crossover in the heads then just cut a soda/beer can to support the intake manifold gasket at the exhaust crossover. This will block the hot exhaust. Many members have done that succesfully.
Olds64 is offline
Old March 5th, 2018, 08:07 PM
I was thinking about fitting the plug then drilling a 3/8 hole on each side of the plug. Drill 50% of the plug, and 50% of the head on a drill press. Then tap the hole and then get a 3/8 plug with an allen. Then torque down the plug so it fits snug.
Shouldn't go anywhere at that point?
VinMichael is offline
Old March 5th, 2018, 08:20 PM
Bernhard's Avatar
I have used the steel block off plates with very good results that Dave Smith made. I was just looking for even better method for heads that have already been machined.
Thanks for the links and feedback
Bernhard is offline
Old March 5th, 2018, 08:21 PM
Bernhard's Avatar
I'm having a hard time visualizing this method.
Thanks for the reply.
Bernhard is offline
Old September 20th, 2018, 06:31 PM
Dont use epoxy it will melt all over the top of your pistons and glob up on your exhaust valves and hang them open and you will crash it into your piston
on top of much more damage !
w30442 is offline
Old September 23rd, 2018, 12:19 PM
Melt a piston down and fill it in the right way.
VORTECPRO is online now
STLCRZY
April 28th, 2017 06:36 AM
67Rocket
Paint
March 4th, 2016 09:18 AM
dnmfranco
March 24th, 2014 11:41 PM
1977 Delta 88 Flint
December 25th, 2012 12:25 AM
bjtstarfire
November 13th, 2008 03:04 PM
Quick Reply: Heat riser block off epoxy & plugs together???
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
