Main Cap Stud Question
Hi All,
I've been doing some reading through Bill Trovato's book and he says that the main webs on Olds gas blocks are weak and eventually, under too much power, the caps walk and eventually fail. He recommends a main cap girdle, but I'd like to avoid the cost and modifications involved. Can I throw on a set of ARP studs and rest easy, or is a girdle the way to go? I'm not trying to make crazy power, I just don't want to run over my crankshaft if I try to throw nitrous at it.
As always, any and all info is much appreciated!
P.S., if you have tried and true combos for a 350 or 455, I'd love to hear about them!
Rotating assembly would be stock crank (or Eagle for a 455). Better rods (haven't done any looking yet) better pistons (haven't looked). the goal would be streetable 450 with a 350 and closer to 650 for a big block. has anyone gotten really crazy with a 350 and made more than 550 with one?
My stroker small block should make 550+, I'll keep you posted on that.
If you're trying to make 650 with a big block you'll need either an aluminum rodded rotating assembly, or halo and studded mains, H beam rods and a good forged piston. Otherwise you'll have parts all over the street.
My small block has a 1/2" 5 main halo with studs and happened to have excessively thick cyl walls as compared to other gas blocks I've had checked.
And that's NA right? Would you trust it with any sort of boost or nitrous? Basically my goal is to not have to use a halo or any sort of girdle, they're kind of expensive and need mods done to the oil pan, unless i'm mistaken. i know no power comes cheap, but i'm just trying to see how realistic making power with an Olds block is without a girdle
Which pictures of mine would you like to see, the ones where it broke the crank into 2 pieces and ripped out #4 main bulkhead, or the ones where it broke the crank into 5 pieces and ripped out #2, 3, and 4 bulkheads? Or, I can show you the pictures of the 2 girdled blocks that each had a failed crank, but no damage to the block in any way.
I've always used the 1/2" J&S stuff, good quality and fair price. But I know there are other good ones out there.
Not sure how much he cut the caps but just enough to make them flat all across the top. Yes align hone is mandatory at that point.
J&S supplies the dimensions needed to install his 5 main halo, basically the front 4 main caps are cut to be the same height as main number 5. Align hone main bores at a minimum, might need an align bore if factory cut is not straight.
