3/8 fuel lines and fuel pump
Old November 13th, 2017, 08:26 PM
Daniel828's Avatar
I have a 1966 cutlass, 455 with a quadrajet and realized this weekend that the fuel bowl was running dry while drag racing. Works great on the street but not so great when the 2-3 shift happens it just falls flat. It has the original 5/16 line, with new sending unit and fuel pump. I’m planning on switching over to 3/8 line but which fuel pump works with the 3/8 line. And which pump to carb hard line do I use?
Dan
Daniel828 is offline
Old November 14th, 2017, 12:02 AM
Gerald Nickels's Avatar
I do know 65 Cutlass with a 330 is 5/16" and 65 442 400 motor is 3/8" that's one way to tell if real 442 or not but lines can be changed but body must lift up for replacement of 3/8" fuel lines.
Gerald Nickels is offline
Old November 14th, 2017, 12:08 AM
My street and strip 64 F-85 post had a 425 Olds with the stick W-30 cam and 400 trans with 350 convertor and a W-37 3.91 and 66 Tri-Power, posi ran 12.50 at 110 MPH all day never had a problem running out of gas with a 5/16" line. I think the tri power used more gas and never pinged.
Old November 14th, 2017, 05:00 AM
jcdynamic88's Avatar
you may want to enlarge the tiny holes in the carb that fill the secondary wells,this worked for me when i transferred a 66 442 drivetrain into a 65 cutlass that had the same issue.
jcdynamic88 is offline
Old November 14th, 2017, 06:14 AM
Run to Rund's Avatar
Delete the mechanical pump and use a Holley red pump.
Run to Rund is offline
Old November 14th, 2017, 10:38 AM
edzolz's Avatar
With 3/8 line?
edzolz is offline
Old November 14th, 2017, 12:10 PM
shiftbyear's Avatar
what qjet number are you using? There is a larger needle and seat available, drag racing may require a slightly higher fuel level setting. You may require a different pickup in the tank if fuel is rushing to the back of the tank during launch and leaving the pickup exposed. Larger lines and electric pumps are preferred. Contact Cliff Ruggles if possible. Good luck.
https://cliffshighperformance.com/
shiftbyear is offline
Old November 14th, 2017, 03:42 PM
Bernhard's Avatar
Check out Cliffs feed back on running a return line in the form section.
Bernhard is offline
Old November 17th, 2017, 02:44 PM
Daniel828's Avatar
Thanks for reply’s guys. The quad is a 7042040. I think it’s a Buick carb used on their 455s. I emeailed Lars Grimsrud, I explained the situation and he said mostly likely fuel starvation. I’ve ordered a 3/8 sending unit and my fuel pump inlet is 3/8 so I’ll just have to figure out fuel line. I don’t want to lift the body and I don’t care about originality so I’ll just snake a braided line over the rear crossmember. That’s my biggest concern with this retro fit. But I’ve got all winter to do this and some head work
It runs 8.55 in the 1/8 but id like it a little faster. We’ll see
Old November 18th, 2017, 06:40 AM
TripDeuces's Avatar
Sock on pick up could have collapsed or maybe another obstruction. Disconnect the fuel line at the pump and blow air in to clear it. The sock on my 66 collapsed flat.
TripDeuces is offline
Old November 18th, 2017, 08:49 AM
Originally Posted by edzolz
With 3/8 line?
yes, that is what I run.
Old November 18th, 2017, 09:34 AM
Bernhard's Avatar
Hi
What kind of pump are you running and are you using a return line?
How fast is the car ET MPH and when do you think a 1/2 inch line would be the way to go?
Bernhard is offline
Old November 18th, 2017, 12:41 PM
Daniel828's Avatar
I’m not sure on what brand the pump is. It’s from rock auto There isn’t a return line on it. The sending unit is less than a year old but it’s a 5/16 line size unit.
What I’m going to try to do is cut the barbed fittings off of the pump and sending unit and use earls hardline adapters to -6an fittings and run braided 3/8 line from tank to pump
Old November 18th, 2017, 12:44 PM
Daniel828's Avatar
The car ran an 8.55 at 84 mph in 45 degree weather last week. That’s the best it’s ever gone but I couldn’t duplicate that and it was running 8.6 to 8.7 with the fuel problems If I kept it floored is when the problems happened so if I only was in it 3/4 throttle it would run ok but that’s hard to modulate during a race
Old November 18th, 2017, 12:48 PM
Daniel828's Avatar
One last thing Sorry about all the posts I keep thinking of stuff to add
If I go up to 1/2 inch line that raises more problems. Is there a fuel pump with 1/2” fittings? How about a 1/2” sending unit? And I’d need a 1/2” line from pump to carb. Just brain storming here
Thank you everyone for your input
Old November 18th, 2017, 01:34 PM
Bernhard's Avatar
Are you going to be using the 5/16 line as a return?
Bernhard is offline
Old November 18th, 2017, 01:36 PM
shiftbyear's Avatar
before you get too crazy, install a fuel pressure gauge where you can see it while driving. you want to verify fuel pressure is falling off before you spend a ton of money and time on upgrades. good luck
Old November 18th, 2017, 01:46 PM
Daniel828's Avatar
Good point shiftbyear. I’ll do that once it’s back together. I’m gonna do some head work this winter so it’s down for the for seeable future
Bernhard I’m not going to run a return line. I couldn’t find cliffs write up on return lines. I even looked over at his forum and the only return line mention was about running an electric pump.
Old November 18th, 2017, 05:54 PM
Bernhard's Avatar
Oldsmobile ran a return line with a mechanical pump on 442's, W 31's etc.
Bernhard is offline
Old November 19th, 2017, 05:44 AM
sounds like a lot of work and expense for something that could be solved by enlarging the secondary fill holes,i'm running stock 5/16 line on my 65 cutlass with no problems after enlarging them.stock fuel pump,455,q jet,4 spd,4:33s running 12.50@110mph
Old November 19th, 2017, 06:09 AM
Originally Posted by Bernhard
Hi
I run the Holley red pump (no regulator), screen filter at the pump which is near the tank, no return line. I have an Autometer electric fuel pressure gauge with the sender mounted at the carb inlet. Car has run 11.51, 118.97.
Old November 19th, 2017, 07:57 AM
Daniel828's Avatar
Good point bernhard, I didn’t realize that
Jcdynamic88, I have Ruggles quadrajet book. Does it mention anything about the secondary enlargement? I’m curious about this and would like to learn more about that mod.
Old November 19th, 2017, 09:34 AM
Bernhard's Avatar
Thanks for the reply.
11.51 118.97 WOW
This is with your JR stock 400 E right ?
Is the key to your fuel system the lack of restriction as in no regulator and screen filter?
Bernhard is offline
Old November 19th, 2017, 10:55 AM
i've been modifying and racing q-jets for over 40 years and i don't remember where i picked up that tip but it works.there are two tiny holes that fill the secondary wells and it's easy to enlarge them .i believe to 1/16 "
Old November 21st, 2017, 07:49 AM
No special key to my fuel system. The red pump is Holley's "basic" pump with internal regulation to 7 pounds, no external regulator--the blue pump runs 15 lb. and regulates down near the carb. The screen filter is Jegs 15040 filter, 40 micron screen. I run a Caddy Seville fuel pump hole cover from its 350 Olds engine.
Old November 21st, 2017, 07:41 PM
Bernhard's Avatar
I'm a fan of NHRA Stock and the fuel systems I have seen on cars that are not as quick as your car are extremely elaborate.
There is a mirror thread to this on ROP and one of the members their has also noted the hi tech fuel systems found on Stock class cars today.
I was just trying to under stand how you were able to make a dead head system with 3/8 line work so well.
Thanks again for the feed back.
Bernhard is offline
Old November 22nd, 2017, 03:42 AM
firefrost gold's Avatar
Photos ? Video ? or should he send it to you
firefrost gold is offline
Old November 22nd, 2017, 04:12 AM
[QUOTE=firefrost gold;1057435]Photos ? Video ? or should he send it to you [/QU after removing the top of the q jet it's self explanatory,after all it's not rocket surgery.
Old November 22nd, 2017, 07:06 AM
One caveat for you--I run Tri-Carbs which have decent sized fuel bowls. The Quadrajet has a tiny bowl so is very sensitive to fuel supply. With the Holley mechanical pump, I used to run out of fuel at around the 1/8 mile mark, when the car ran 12s.
Old November 22nd, 2017, 08:15 PM
Firewalker's Avatar
Back in the day it was standard for out fast Olds to run a holley red back at the tank and then up to the mechanical fuel pump, and no fuel problems. If I remember right we could switch off the electric in normal driving and just run off the mechanical.
Firewalker is offline
Old November 23rd, 2017, 10:14 AM
  #31
Bernhard's Avatar
Thanks for the reply and lesson.
So your system might not support a 11.50 Quardrajet car but works fine with the Tri power set up.
So the elaborate stock class fuel system, just removes any possible concern with fuel delivery
given the Quadrajet bowl size.
Now that I think about it,the cars that I seen with these expensive fuel systems were all running Q-jets.
Next points meet I'm going to pay closer attention to what non Q-jet cars are running for fuel delivery systems.
Bernhard is offline
Old November 23rd, 2017, 04:04 PM
  #32
Firewalker's Avatar
[QUOTE=Bernhard;1057724]Thanks for the reply and lesson.
Next points meet I'm going to pay closer attention to what non Q-jet cars are running for fuel delivery systems.[/QUOTE
Dwight Kohout said on his 455 I believe he had fuel problems around mid to low 12s 111mph plus with his mechanical fuel pump supply to his Quadrajet, and added an electric pump booster to get down to about 12 flat without problems.
A 3/8”id fuel line can easily support 600 HP given sufficient “pump head”! Given a big enough pump a 3/8” steel line could support 1000 HP.
http://ipgparts.com/blog/fuel-line-s...ize-do-i-need/
brownbomber77
October 12th, 2017 05:22 AM
theold52
February 22nd, 2017 07:51 PM
Kyle's 77 Cutlass
May 15th, 2014 09:05 PM
onofre442
July 24th, 2012 01:19 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
Quick Reply: 3/8 fuel lines and fuel pump
