350 Olds Build Questions
I have a 350 Olds 77-80 with a Comp Cam XE262h, full length hedman headers, holley street dominator intake, holley Ultra 650 DP, true dual 40 series flowmaster, 3:73 gears, posi, and hei. Pretty basic. I just purchased some rebuild 7a heads. I would like the compression higher but my budget is not agreeing. Pistons, rings, and boring it out would be nice tho. I think I’ll just put my heads on and call it a day. What gaskets should I use? & will I see any difference from the 3A heads that I have ?
*I wanted a weekend cruiser. Not too much but more than stock in my 1987 Cutlass Supreme.
I used the .028" Rocket Racing head gaskets. Unfortunately, they are now on back order. With a 62-64cc chamber and the thin gasket, I came out right at 9 to 1. Smitty from M&J Performance had .011" thick shim gaskets for around $100 a pair. Also .027" reuseable but around $150 to $200 a pair gor the superior Cometic gaskets. I know the 77-80 Olds 350 uses a unique head gasket. I can't remember if you use early head gaskets when you switch heads. Expect 8.5 to 1 with Felpro replacements but those heads are definitely better. Stock valves or any milling? CC them and go from there.
You can use copper coat gasket spray on the shim gaskets but there should be no issues with iron heads. A Performer RPM intake is a better choice for your current and one with slightly more compression. The 650 is borderline too small as well.
okay. Sounds great
