Bracket Issues after Aluminum Head Swap, Olds 455 Please Help!
Old October 2nd, 2017, 03:29 PM
HelpMe's Avatar
Any advise would be greatly appreciated, I rebuilt my Olds 455 and decided to go with the Edelbrock Heads, my Altenator Bracket now does not fit, the Air Conditioning Compressor is having the same issue. I haven't got to the power steering yet but because it's mounted on the lower section of the block I think it may be in the clear. And advice or past experiences would be greatly appreciated,
Thank you
Your fellow BOP friend...
HelpMe is offline
Old October 2nd, 2017, 04:57 PM
Hookers under Hood
76olds's Avatar
Can you post a few pics showing how far the holes are out? Can you oblong the hole a little to make them work?
Eric
76olds is offline
Old October 3rd, 2017, 11:52 PM
EightballZ's Avatar
in my experience you just have to grind some material off of the brackets..no big deal
EightballZ is offline
Old October 4th, 2017, 09:48 AM
Once Olds Always Olds
Troys Toy 70's Avatar
I just did this on my 455 with pro comp heads. 70 442. I am assuming you have an elderbrock intake as well. The front alternator bracket that bolts to the head directly has a lip on the upper and lower side of the bracket on the back side. Grind that lip flush with the bracket going back about an inch on the lower one, and the alternator brackets should bolt up fine from there.
Assuming an aftermarket intake the hole in the a/c bracket that bolts to the intake will need to be oblonged to accommodate where the intake bolt hole is. If it is an elderbrock intake it will require a smaller bolt.
Troys Toy 70 is offline
Old October 10th, 2017, 01:59 PM
mrw8i's Avatar
This ^^ on the alternator bracket that bolts to the front of the head. Power steering should have no problem.
mrw8i is offline
66luvr
April 2nd, 2014 07:36 PM
1965F85_scholten
July 13th, 2013 02:57 PM
antweave
July 26th, 2011 09:04 PM
kandelino
December 20th, 2010 12:54 PM
Quick Reply: Bracket Issues after Aluminum Head Swap, Olds 455 Please Help!
