2 piece timing cover - ClassicOldsmobile.com
Old July 30th, 2017, 05:24 AM
Hi guys, anyone built they own 2 piece timing cover from a existing.
Know that stolpa sells these covers, ask my self why not cut my used in half and go on.... ?
input please!
Tiha is offline
Old July 30th, 2017, 07:41 AM
I have one that is cut from a original cover. Never used it.
wr1970 is offline
Old July 30th, 2017, 12:42 PM
bccan's Avatar
I made one off stock cover. Bent a little piece of sheet metal into roughly a soft "z" channel & tacked it onto upper half. Acts as sort of a canopy over the joint + forms a trough/dam to help retain bead of RTV. Doesn't leak & have no plans to use it, just a MAW that has been transferred from engine to engine.
bccan is offline
Old July 30th, 2017, 04:01 PM
RROLDSX's Avatar
I tig welded an 1/8" strip on the lower half, split the bolt holes in half. Using grey silicone it has no leaks.
RROLDSX is offline
Old July 31st, 2017, 04:45 AM
Really cool guys, is it important to split the cover directly at the bolt holes.
maybe someone can insert some pics ??
Tiha is offline
Old July 31st, 2017, 06:35 AM
I have made them by cutting across the upper 3/8" bolt holes, seal with RTV. Has worked for 44 years. No flap, no complicated stuff.
Run to Rund is offline
Old August 3rd, 2017, 04:44 AM
Originally Posted by run to rund View Post
i have made them by cutting across the upper 3/8" bolt holes, seal with rtv. Has worked for 44 years. No flap, no complicated stuff.
thanks...my way!
Tiha is offline
Old October 29th, 2017, 08:03 PM
Unless your changing cams all the time, not needed
honkeycat is offline
Old October 31st, 2017, 04:30 PM
MOTORHEAD
11971four4two's Avatar
[QUOTE=honkeycat;1052749]Unless your changing cams all the time, not needed[/QUO
LoL
maybe you would like to change your cam degree / timing
if you do your 2 piece right
you can keep water pump bolted to the up segment
11971four4two is online now
Old October 31st, 2017, 04:39 PM
MOTORHEAD
the wagon was all stickered up
TRI CITY Competition
from michigan
were you there???
please tell me more
THANKS
b
Old November 9th, 2017, 05:16 PM
[QUOTE=11971four4two;1053202]
LoL
lol I have a 2 piece timing cover
Almond900
November 1st, 2016 09:29 PM
jpc647
June 10th, 2013 11:48 AM
Mr Nick
November 10th, 2012 09:33 PM
Indy_68_S
Brakes/Hydraulic Systems
January 2nd, 2011 09:23 AM
442scotty
May 13th, 2009 05:42 PM
Quick Reply: 2 piece timing cover
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
