no baffles, valve covers
Old June 25th, 2017, 05:02 AM
W30
truckman5000's Avatar
I have roller rockers and the valve cover baffles removed completely. I have the 2 breathers attached to the oai air filter. I obviously have alittle oil in the air filter housing, Is this an issue?
Also the intake rubber 90. That connects vacuum to the carburetor is leaking oil. So im assuming there is no valley pan?
The engine has been built before me, with not allot of miles on it, the oil pan was modified, looking in the oil passages cleaned, roller cam/ rockers. So maybe theres a reason the valley pan isnt on..
truckman5000 is offline
Old June 25th, 2017, 06:40 AM
72 Olds CS
RetroRanger's Avatar
No baffles means sucking oil, usually people will fab a small baffle or I've read of a rubber grommet w a baffle built in.
Re valley pan one should be used but trimmed to fit w your set up
RetroRanger is offline
Old June 25th, 2017, 08:55 PM
Chevy budget Olds powered
coppercutlass's Avatar
I made baffles using washers and a zig zag plate set up on a riser stack for the breather. worked very well.
coppercutlass is offline
Old June 30th, 2017, 01:33 PM
boese1978's Avatar
I have no baffles in my roller set up, no leaks at all, just need to get the proper size grommet for the hole in the valve cover and the breather or PCV you are using
boese1978 is offline
Old June 30th, 2017, 03:40 PM
ferndaleflyer's Avatar
How about this---My race car smoked out one header for a whole season and I thought I checked/changed everything without getting into the motor which ran fine. Turned out I had switched the valve covers from left to right and one of the rockers was flipping oil right up into the opening for the evac hose. I haven't seen those pans under the intake used in years but I suppose they use them on stock engines. We currently use a Victor manifold and have a pcv valve tapped right into the valley and into the manifold right under the carb----zero oil leaks anywhere.
ferndaleflyer is offline
Old June 30th, 2017, 03:46 PM
If you find your using a bunch of oil then you need to do something. If its just a small amount just wipe it up periodically. Most do not use the turkey tray with roller lifters because they need to be trimmed.
oldcutlass is online now
Old June 30th, 2017, 05:17 PM
W30
Thanks guys, seems fine.
But the vacuum 90 boot on the top of the manifold spews oil onto the intake after driving acouple miles. I tried a hose clamp, this is my main concern ill take a pic
Old June 30th, 2017, 05:49 PM
W30
pic
Old June 30th, 2017, 05:51 PM
W30
After 20 miles it will fill half the chamber area of the manifold, stock there isnt a clamp..?
Old July 2nd, 2017, 08:00 AM
dc2x4drvr's Avatar
No clamp on the boot, if you don't have a modified turkey tray, or valley tray you're gonna have oil pumping up through the nipple, I'd plug the hole.
dc2x4drvr is offline
Old July 2nd, 2017, 10:41 AM
W30
the 90 in vac. to carb. right? Is it can be plugged?
Old July 2nd, 2017, 01:21 PM
dc2x4drvr's Avatar
Yes, that is not a vacuum port, it is for a pcv valve, and should be connected to the large nipple on the carb baseplate. You could pull the intake and install a modified turkey tray, or valley tray which would keep the oil off the bottom of the intake.
Old July 5th, 2017, 06:28 PM
W30
So i can cap the intake and carb end of this hose.? the pcv are on both valve cavers
RAMBOW
March 20th, 2017 06:58 PM
streets
December 27th, 2016 12:45 PM
tim72
June 30th, 2010 04:41 PM
tim72
May 22nd, 2010 08:11 PM
mgue67
April 28th, 2010 10:27 PM
Quick Reply: no baffles, valve covers
