Rocker pivots
Old May 5th, 2017, 01:49 PM
Jimmy946's Avatar
Rocker pivots
I have a 1971 cutlass supreme with a 350 rocket. I am new to olds so I have never encountered rocker pivots. My question is I purchased comp cam roller rockers hydroulic lifters and a new cam and was wondering do I have to use the pivots on there??
Jimmy946 is offline
Old May 5th, 2017, 02:40 PM
same but different
don71's Avatar
No, but those roller rockers you bought need to have the right size stud and thread size. Hopefully you got the right ones..I think the 1441 kit is the right one. Sometimes the push rods length may not be correct but it all depends. If you only purchased the arms, you are not done buying stuff yet.
That other stuff you'll remove and just throw...in a box, after you have what you need.
What exactly did you buy? part numbers...
And welcome to Classic Olds.
don71 is offline
Old May 5th, 2017, 02:45 PM
Olds Fever
CRUZN 66's Avatar
Welcome to the site... No, the stock pivots would not be used with the comp cam roller rockers...
CRUZN 66 is offline
Old May 6th, 2017, 12:34 AM
Jimmy946's Avatar
I purchased comp cams 1441 kit part # 249-1441 with rockers, studs and push rods and Edelbrock performer plus camshaft - edelbrock 3713 part number 350-3712. I haven't Played with motors in over 20 years and they were all chevy. What is the best way to adjust the valves I used to do top dead center take the play out and another 3/4 turn is that what I should do with this set up?? Thanks in advance
Jimmy946 is offline
Old May 6th, 2017, 10:58 AM
edzolz's Avatar
There is no adjustment for stock Olds lifters. For yours, turn over the engine by hand so each set of rockers is where the valve is closed all of the way. Tighten down the nut until the push rod will not spin by hand. Tighten one half more turn and go to the next valve that is closed. That is how I do it, there are others with different methods.
edzolz is offline
Old May 6th, 2017, 12:35 PM
RROLDSX's Avatar
You will have to check your pushrods lengths for proper geometry and you may need to exchange your push rods for longer or shorter. You will need an adjustable push rod to check for the proper length required. Depending on the cam grind, head gasket thickness, head shaving, rocker arm design and spring height can all change the geometry. There are several instructional videos on Summit Racing, Comp Cam and Youtube.
RROLDSX is offline
Old May 23rd, 2017, 10:33 AM
Jimmy946's Avatar
Does anyone know what exhaust donuts (part number)go on my 1971 cutlass 350 rocket when I bought the car it was in peaces and they didn't come with the car. A guy at napa gave me some that he thought went on the car but I don't believe that are the correct ones since they crush when I tighten them down
Jimmy946 is offline
Old May 23rd, 2017, 02:31 PM
same but different
don71's Avatar
You shouldn't need a doughnut style gasket. This joint is usually metal to metal no gasket. Some of the big block manifolds use a flange gasket, one side is a flange the other doughnut like. Some 307 use a doughnut but yours should not.
don71 is offline
Old May 25th, 2017, 08:11 AM
Jimmy946's Avatar
i have the one that is half flange half donut but it just don't seem right
Jimmy946 is offline
Old May 25th, 2017, 11:24 PM
MOTORHEAD
11971four4two's Avatar
I thought there was a torque to foot pound # on the rockers???
stock configuration
11971four4two is online now
Old May 27th, 2017, 11:10 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Stock configuration is tighten to 25 ft/lbs, I usually tighten the pair evenly together. I personally like the stock set up, which fine for cams that are not too radical.
olds 307 and 403 is online now
Old May 27th, 2017, 12:19 PM
The OP doesn't have stock rockers, he has Comp Cams 1442 roller-tip rockers (this is what comes in the 1441-kit). Read the instructions that come with the rockers - they tell you exactly how to adjust them. I ASSUME the OP has installed the necessary studs and guide plates, right?
Note that the 1442 rockers use ball pivot, just like a Chebby.
joe_padavano is offline
Macadoo
February 10th, 2016 05:32 PM
Arrowstorm
January 27th, 2015 03:38 PM
442bob
November 9th, 2011 04:31 PM
CutlassLegend
September 21st, 2011 02:56 PM
Quick Reply: Rocker pivots
