Harland Sharp S4003 Ford Rockers
Old May 3rd, 2017, 08:30 PM
71DP's Avatar
Has anyone used the Harland Sharp S4003 Ford rockers? I assume this will work on the Olds? Using the Comp 5/16 x 3/8 studs, guideplates and custom pushrods?
71DP is offline
Old May 4th, 2017, 06:51 AM
TripDeuces's Avatar
Supposedly the push rod cup angle is different between the Olds and Ford. Harland Sharp makes Olds specific rockers.
TripDeuces is offline
Old May 4th, 2017, 06:26 PM
71DP's Avatar
I was looking for a 3/8" stud. It appears the Olds specific ones are 7/16 only
71DP is offline
Old May 4th, 2017, 07:27 PM
Hookers under Hood
76olds's Avatar
you will need to machine the Olds ones to make them work.
76olds is offline
Old May 5th, 2017, 05:31 AM
Old(s)GuysRule
67OAI's Avatar
Have you called Sharp (Custom Speed Products)? They may build you a set of the Olds rockers for use with 3/8" studs.
67OAI is offline
Old May 6th, 2017, 06:13 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I have a set of Scorpion SBF 1.72 ratio roller rockers for a 3/8" stud, if you are interested. I will include the 3/8" studs and guide plates and even pushrods if you want. Make me an offer.
olds 307 and 403 is online now
Old July 2nd, 2017, 02:45 PM
MOTORHEAD
11971four4two's Avatar
HI GUYS
Yesterday I bought some rocker arms
H-5003
they are steel roller
Are they harland sharp???
THANK YOU
11971four4two is online now
Old July 2nd, 2017, 02:49 PM
Those Rockers you bought are probably copies of the Crower or Comp steel rocker arms. All Harland Sharp rocker arms are orange aluminum true rollers.
Old July 2nd, 2017, 03:11 PM
MOTORHEAD
Cool
thanks
Stevec
April 11th, 2012 01:04 PM
bosch 68 442
June 29th, 2011 05:02 PM
70OLDS442
November 21st, 2007 05:00 PM
Quick Reply: Harland Sharp S4003 Ford Rockers
