Upgrading a Batten Headed 455 originally built by Joe Mondello 20+ years ago
#241
The heads look awesome, and we can't wait to see how The Isky cam runs that was installed and degreed today, and dialed in to a 104 I.C.
We will be mocking up a head and checking for piston to valve clearance tomorrow with clay to make sure the new cam doesn't slam the valves into the pistons; fingers crossed.
#242
#243
Lift is in the low .600's on intake and exhaust with a 1.7 rocker...
We checked the Piston to Valve clearance today and it wasn't nearly as much room as before, as it had about .140 clearance on the exhaust side this time.
#245
Yes, all will be fine....
We torqued the heads up tonight and took some measurements for the intake manifold machine work still to come.
Everything is looking good and going back together very well.
Going to clean the new 1.7:1 HS rocker arms in Mineral Spirits, dry them well, then soak them in oil and start checking for pushrod length tomorrow if we get time.
#247
We got it all back together today....
Here are teaser picks of the intake porting work by Eric and Mark at Vortecpro.
Aside from the awesome port work, what you can’t see is the 5 lbs of aluminum that had to be removed from the intake to make it fit the heads. This was a rough-finished Intake, and I know what the before and after looks like, and there was literally pounds of aluminum removed from the gasket faces to make this intake fit with true precision!
Next week, maybe Dyno testing of the new upgrades!
#248
Nice
The heads look like they will deliver as does the intake.
Mark does top shelf work.
I'm looking forward to your new dyno numbers.
Thanks for sharing
Thanks for sharing
#249
Dyno Data Today!
Thanks again to Vortecpro for his huge effort on this project with my Dad and I.
This is going to make a very nice Street/Strip combo for us, and we can’t wait to finish the car and make some runs.
Also, I meant to get a picture of all of us standing with Harold Bettes, who was there most of the day, but we were so busy making horsepower and talking engines that I forgot to do so.
Harold was there to hang out with us and to share some of his knowledge with us and answer some questions I had, as well as to watch an Olds engine pass a pretty good number.
Mark says there is still more in it with with an improved distributor and a little more fuel curve refinement, and Mark and Harold suggested longer collectors would likely add more power.
All in all, we started at 8:30 this morning, and got done at 7:15 tonight, it was a long day filled with hearing an Olds grunting out some good power, with lots of little corrections to all add up.
#255
I would bet we could have seen another 15 +HP with a modern piston and ring package. Also, Locking out the distributor and upgrading to a crank trigger could have added another 5-10hp more.
Adding longer header collector extensions might add another 5-10hp.
Shimming the hydraulic lifters to convert them to be “solid” might add another 10hp.
So, moving forward, we might still modify the lifters in the future, we are already going to change to a Holley dual-sync distributor when we switch to fuel injection, and we will likely play with the header extensions at the track for the fastest times when we install an exhaust system and cutouts possibly.
We may be able to add 20-30hp more to the combo, especially if we can get a good tune with E85 vs. 91 octane pump gas the engine ran the numbers on the dyno with.
We won’t be changing pistons in the foreseeable future.
#257
I was thinking it will be the same or better with EFI, especially with an injector plate below the throttle body to introduce fuel to the plenum instead of installing bungs and making it a true MPFI. I think EFI will shine because I can tune it for all fuel types, using the same injectors. I figured I could increase the fuel pressure to 60psi or more if needed to get the target lambda with E85 using these Green Giant injectors.
#258
127 MPH @ 3700 pounds = 584 crankshaft HP
1320/127 = 10.39 ET
#260
BUT your infinite timing control with EFI will give you as much of a benefit as any other feature.
#261
I can't wait to pull the wheels!
#262
With the intake and a "wet-flow-plenum" fuel injector setup, I think we will be in good shape on the air-fuel variations of the tune, especially with fully graphed spark control for all possible map conditions.
#266
Hello OldOlds442,
I am confused of what you are asking, sorry.
Are you asking how much it would likely cost someone else to build this combo like this again, or are you asking what it actually cost us?
#270
Battenrunner, this was quite the post! Filled with ups, downs, drama but most importantly a ton of good information.
I'm glad you finally got to the "finish" line with this engine build. Now it's time to enjoy it in real life.
Good luck to you and your father at the drag strip!
#271
I had lunch with Battenrunner today, I asked him about this post, and heres what he told me, approximately a 7200.00 investment at this point. Hope this answers your question.
#272
Thanks for Posting that up VORTECPRO!
Also, thanks to all for the support on our long road to success!
I have been so busy with work that I really haven't had time to post anything on here for days..... So I apologize for that.
That $7,200 could have been even less if we wouldn't have wasted money on the drama with Mile High Crankshaft and the first go-round with the heads, and the first cam grind, having to buy new bearings for the rods and mains......
Luckily, we kept it more affordable by selling whatever we weren't using that were still good parts, so that kept our cost down a little bit as well.
We do have an ATI SFI approved balancer on it now, as well as an SFI approved Billet steel flexplate, so I feel safe with those parts on-board, especially if we go to a lower elevation track and see more of the real power this engine is capable of.
In the end, we have a very solid engine, with proven durability and power numbers on a dyno with many runs, and it wouldn't have even ran more than a minute with how it came set up originally, or the first, or second time the crank was reground by someone else, before VORTECPRO got it fixed up.
If someone wanted to replicate the build, it is difficult to find many of these parts, but not impossible, and could definitely be done. As for replicating the machine work and attention to detail, not many will be willing or able to do so.
#276
Thanks so much Sonoman. I hope our struggles and lessons-learned will help others to see what can go wrong, as a lot of things did.
The original built engine was a total cluster, and would have never lived for more than just a few minutes at best with the issues present.
I will be watching for your engine thread and I wish you good luck !
#277
Decided it was time to remove the engine and pull the ported intake and send it off to get it machined and set up for the fuel injectors and rails the right way to fully utilize the Motec M8 sequential EFI. The intake was originally just rattle-can painted, and so it will probably be touched up/repainted now.
We have been mocking up everything to check for space and clearance and adding corrections as they are necessary.
#279
We are excited about it!
Holley dual sync distributor for cam and crank signals
As for the ignition box, we have a brand new old stock Motec single channel CDI ignition box # 41009 with a single Mercury Marine CDI coil (the type that has the female coil wire terminal and has nuts on the power and ground terminals).
