Hyd. Roller in DX block
When using the stock hyd.roller lifters and dog bones in a DX block is a small base circle camshaft required? I believe I have read in some old posts here and on ROP that to get up to around.360 lobe lift you would have to have the cam ground with a smaller base circle. Thanks in advance
dx block
So about .480 lift with 1.6 ratio rockers for the 400E/425 blocks. I could live with that. Thanks for the clarification on that Mark. As usual, you're there to help us old timers out. George.
