72 Cutlass Supreme Body Side Molding
Moulded
If Tom doesn't, which I am surprised he even needs to look....since his shop is so sickeningly better organized than mine will ever be.....cough cough, ahem JK!.....
I am sure I have one.
Brett
Brett
I got it, $20.00 plus shipping.
It has a couple of small dings in it. I couldn't quite get a picture of the dings but it's not perfect.
If you want to check with Paladin31 to see if he has better one before deciding I'll understand.
5/8 by 30 at the longest point...it has a diagonal cut on the end that butts up to the wheel well arch. The piece that you're showing goes on the front fender. Going towards the rear, next would be the door piece, then the piece on the front end of the quarter to the wheel well arch and then the last piece that runs from the back side of the wheel well arch almost to the bumper....which is what I'm missing. thanks for checking.
Molded
Tom- thanks good suggestion!
Scott- I will check tomorrow evening as I have a 72 more door in the yard that has the side moldings. And in the twilight it appears to be 5/8 x 30 ish, although I doubt a 2 & 4 would share that same trim. I sent pics of what I 'thought' was the real deal, but all the cars Ive had/stripped none came with that originally. Sorry
Thank you both for the info.
Brett
Brett
That's the deal! Other side though. Interesting that it's on a Cutlass...thought it was specific to the Supreme. Guess the body panels are roughly the same dimensions so it works on either. I'll look for the ds pics...thanks!
w31man
February 7th, 2013 05:04 PM
1968Cutlassfallbrook
December 13th, 2010 06:30 PM
