Gauging Availability: 330 flexplate
Old October 24th, 2014, 01:49 PM
'72 Supreme vert (Mango)
adis's Avatar
I've got a line on a std/std 330 crank for a decent price, and am trying to gauge availability of flexplates. Who's got any and how much (shipped to 21032)? I've seen them for as low as $35+. I don't necessarily need it right now (nor do I really need the crank for that matter) but I can't seem to pass up a good deal... Thanks - mark
adis is offline
Old October 24th, 2014, 07:21 PM
oldolds88's Avatar
how many do you want,i have some.
oldolds88 is offline
Old October 24th, 2014, 08:08 PM
stan 65 cutlass's Avatar
i paid $120 plus shipping, resurfaced, seems about typical
stan 65 cutlass is offline
Old October 24th, 2014, 09:10 PM
adis's Avatar
thanks for the replies, guys. OO88 i sent you a PM. - mark
adis is offline
Old October 25th, 2014, 01:43 PM
"Resurfaced"????
He's asking about a flexplate, not a flywheel.
joe_padavano is offline
Old October 25th, 2014, 02:22 PM
TripDeuces's Avatar
Joe beat me to it.
TripDeuces is offline
Old October 25th, 2014, 03:24 PM
Run to Rund's Avatar
You also need the 330-425 harmonic damper and timing tab. I have them, and a couple flexplates.
Run to Rund is offline
Old October 26th, 2014, 03:43 PM
adis's Avatar
thanks for the clarification, guys. yes, this will be going in a 350 mated to a 200r4 (thats the plan, anyway.) so, not looking for flywheel.
R2R, i sent you a PM.
adis is offline
Old October 26th, 2014, 11:11 PM
johnnyjaws's Avatar
make sure u have it standing up and not lying flat on the ground will warp !!
johnnyjaws is offline
Old October 29th, 2014, 11:36 AM
adis's Avatar
regarding the damper and timing marks - if I've got a 395558 350 block with a 381919 330 crank can I:
use a 2-peice 330 damper with the 330 timing tab? - with the 350 timing tab? (will a 330 tab ('65+ i presume) bolt to a 350 block ?)
use a stock 350 damper with either tab? (are the 330 and 350 dampers interchangeable, or can a stock 350 damper be used on a 330 crank?)
use an aftermarket 350 balancer with either tab?
actually, there are a lot of combinations - how about this instead: what would be the preferred method of marking timing using the above block/crank setup, with stock 330, stock 350, and aftermarket 350 dampers available to me, and not caring about looking stock? thanks for any info (this question probably ought to be under another forum...)
adis is offline
Old October 29th, 2014, 01:23 PM
"Resurfaced"????
DOHH!! Oh brother, musta been drinkin when i read this one. ill shut up now and go back to readin posts
Old October 30th, 2014, 04:57 AM
ROCKETMAN269V's Avatar
[QUOTE=adis;758675]regarding the damper and timing marks - if I've got a 395558 350 block with a 381919 330 crank can I:
use a 2-peice 330 damper with the 330 timing tab? YES
with the 350 timing tab? NO
will a 330 tab ('65+ I presume) bolt to a 350 block ? YES
use a stock 350 damper with either tab? NO
are the 330 and 350 dampers interchangeable? NO
can a stock 350 damper be used on a 330 crank? NO
use an aftermarket 350 balancer with either tab? NO
The timing tabs will physically bolt to either block; but, you have to use the correct balancer for the crank that you use.
Last edited by ROCKETMAN269V; October 31st, 2014 at 05:25 AM. Reason: error in reporting
ROCKETMAN269V is offline
Old October 30th, 2014, 07:20 PM
wr1970's Avatar
[QUOTE=ROCKETMAN269V;758851]
with the 350 timing tab? YES
So is a 425 and a 455 the same timing tab?
wr1970 is offline
Old October 30th, 2014, 08:03 PM
adis's Avatar
thanks for the info, Rocketman!
adis is offline
Old October 31st, 2014, 05:25 AM
timing tabs
I have enclosed pics of the three basic timing tabs; the first, with the cutout numbers, is for the early forged cranks (330, 400- 1st design [ "E" blocks, '65-'67], 425); the second is the first type (stamped steel) for cast cranks (350, 400- 2nd design ["G" blocks, '68-'69], 455); the third is a plastic timing tab for "late model" cast cranks (260, 307 and late 350s). The plastic tabs are used on engines originally built with HEI, which has higher limits on the ignition timing. I hope this helps clear up some of the confusion.
I had to edit my previous post about the use of a 350 timing tab with a 330 balancer; the TDC mark is in different places on these two.
Old October 31st, 2014, 05:28 AM
[QUOTE=wr1970;759104]
No, the forged cranks use one style of timing tab and the cast cranks use another; the TDC marks are in different locations.
Old October 31st, 2014, 09:55 AM
adis's Avatar
this is good gouge! mod, perhaps this thread should be moved to tech & ref
was there a damper used in '64 with the rt hand timing tab? or was it just the balancer? i'm wondering if I need to determine whether my 330 damper is '64 or after?
adis is offline
69Rocket350
February 3rd, 2012 04:53 AM
mauls
December 2nd, 2010 12:55 PM
scubastever
March 21st, 2010 12:36 PM
Steve O
December 12th, 2008 09:22 AM
78cutlass
March 27th, 2008 04:46 AM
Quick Reply: Gauging Availability: 330 flexplate
