Need high output alternator for 68 Cutlass 350 100+ AMP
Old February 29th, 2012, 11:31 AM
yeahbuddy's Avatar
Was going to order a chrome 120 AMP from ebay for around $65 but I thought I'd check to see if you guys had any high output alts laying around. My 60amp is not cutting it when I have my lights and wipers on at idle for a while.
yeahbuddy is offline
Old February 29th, 2012, 12:38 PM
1968 Olds Cutlass S
jdana24's Avatar
I just took a chrome alternator off of my car. Sent you an email.
jdana24 is offline
Old March 1st, 2012, 05:01 AM
ROCKETMAN269V's Avatar
Post high output alternator for 68 Cutlass
If you're running a stock alternator/mechanical regulator combination, the output can be adjusted. You need to find a "mechanic", not a technician, that is familiar with the early charging systems. I'm NOT trying to bad mouth younger repair people; most just have not had any experience with the older systems. Any good repair manual that covers your year vehicle will explain how to check and adjust the regulator.
ROCKETMAN269V is offline
Old March 5th, 2012, 03:29 PM
oldsmobuser's Avatar
Powermaster makes a nice alternator and fairly reasonable ! (Summit or Jegs) You don't want chrome trust me I was an auto mechanic for 22 years. You can also bypass your external regulator and use an internally regulated 120 amp alternator from a mid 80's GM vehicle. Mine came from an '85 Corvette. The case is a little bigger and there are some other differences which I can explain and tell you how to adapt to your vehicle if you like. I have a '68 Cutlass Holiday Coupe that I am restoring, if you know where I might aquire a set of #5 cyl heads I would appreciate it. Thanks.
oldsmobuser is offline
Old March 6th, 2012, 04:22 AM
Smile #5 cylinder heads
Originally Posted by oldsmobuser
If you know where I might aquire a set of #5 cyl heads I would appreciate it. Thanks.
E-mail sent.
WendellB
April 20th, 2015 11:08 AM
cfair
April 29th, 2014 09:19 AM
travisbeamon
March 5th, 2013 10:47 AM
bobfo1
June 18th, 2012 04:37 PM
MLK-442
March 21st, 2012 11:08 AM
Quick Reply: Need high output alternator for 68 Cutlass 350 100+ AMP
