79 olds 350 heads
Old March 25th, 2019, 05:00 PM
69bowtie's Avatar
79 olds 350 heads
Looking for a good set of 79 olds 350 heads for my H/O...did complete rebuild then I let my daughter drive it. She got it hot & cracked heads. I will get some casting numbers this wk. Any help would be appreciated.
69bowtie is offline
Old March 25th, 2019, 05:13 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Bad things happened when my daughter drove my Olds as well. Those 3A Olds heads are very crack prone. There was a bunch of new replacements on Ebay a few years back. There is a couple of rebuilt 3A heads on Ebay right now.
olds 307 and 403 is offline
Old March 25th, 2019, 05:40 PM
69bowtie's Avatar
Thank you! Like I said I haven't looked at numbers yet. Why do they call them 3A heads btw..?
69bowtie is offline
Old March 25th, 2019, 07:34 PM
Olds heads have a number for small blocks and a letter for big blocks near the #1 spark plug. This makes ID very easy. Different years had different heads with different flow rates, valve sizes, etc. so all Olds heads are not created equal.
https://classicoldsmobile.com/forums...r-head-id.html
Fun71 is online now
Old March 25th, 2019, 10:59 PM
svnt442's Avatar
You might want to consider getting some older 350 heads and having the bolt holes bored out for the ½" head bolts. Some 7 or 7A heads would be less prone to cracking and should help a bit for performance.
svnt442 is offline
Old March 26th, 2019, 05:44 AM
I completely agree on older heads. They flow better and will put your compression back 8.5 to 1 without milling. All the later #A heads have horrible exhaust ports with a small 1.5" exhaust valve. Your 3A heads have a well known cracking issue, so even replacements could do the same.
Old March 26th, 2019, 06:19 AM
69bowtie's Avatar
Thank you for all the info. I've already put flat top pistons in it. Are the older head have smaller combustion ports? It's already spark knocks some with the 3a heads, idk about making compression any higher...thoughts?
69bowtie is offline
Old March 26th, 2019, 08:40 AM
The best bet would be #8 heads, I have found 77 to 78cc stock, 79cc is the stock spec, your stock heads are supposed to be 75cc. With a clean up mill, you will only be around 9 to 1 compression with #8 heads. They need a bowl hog cutter under the exhaust valves to flow as well as early heads, there is a lip there but they have 1.625" exhaust valves. A 2" W31 replacement intake valve with a bowl cutter under the intake is also a good idea. What cam? Stock carb?
Old March 26th, 2019, 08:46 AM
69bowtie's Avatar
Stock carb, mild competition cam..it ran good, but didnt like detonation, spark knock issues. Better gas helped some..
69bowtie is offline
Old March 26th, 2019, 08:52 AM
HurstOlds79
walkerkj's Avatar
I have a complete 1979 HO 350 engine for sale. I could probably break out the heads and scrap the rest.
walkerkj is offline
Old March 26th, 2019, 04:36 PM
69bowtie's Avatar
Where are u located & how much?
69bowtie is offline
Old March 26th, 2019, 10:12 PM
That carb is calibrated very lean, doesn't help detonation. What is the duration or cam model? Unless you find the 3A cheap, #8's will help your detonation and they rarely crack.
Old March 27th, 2019, 04:16 AM
69bowtie's Avatar
I"ll have to look up my cam info. Would #7 heads be comparable to #8s..
69bowtie is offline
Old March 27th, 2019, 05:47 AM
No, they are 10cc smaller and 5cc smaller than your current combustion chambers. Where are you located?
Old March 27th, 2019, 05:55 AM
69bowtie's Avatar
I found some #8s in Texas which is close to me. I'm located in Okla. Thanks for all the info! Sounds like uve been through this before.
69bowtie is offline
Old March 27th, 2019, 06:38 AM
You should be able to get the #8 heads cheaper than the early heads. They need more work than earlier heads to flow well but much less than your current heads. Like I said, a bowl hog cutter under all the valves and a 2" W31 replacement intake valves are a good idea. If you have new springs and regular retainers on your current heads, factory on both heads are rotator retainers, those should transfer over. Good luck. My Daughter overheated my Dakota and cracked the Magnum heads in it, also very common. She also ran the 2004R in my 70 low on fluid, left town without telling me, cooked it. Also had a pushrod break while driving it, not really her fault. The oldest daughter fried the original V6 in the Dakota, smashed it up and the youngest daughter has smashed the Tercel twice and nearly ran it out of oil. So yes, I know a bit about both issues.
Old March 27th, 2019, 06:54 AM
HurstOlds79
walkerkj's Avatar
I am located in Sterling Heights Michigan, 48314. $200 for both heads. You can also have head bolts if needed.
walkerkj is offline
Old March 27th, 2019, 04:48 PM
lemoldsnut's Avatar
I have a very nice set of rebuilt 79 403 heads that have no miles on them since the rebuild. Still in the bags.
email direct would give a great deal on them.
Larry
lemoldsnut@aol.com
541-815-4363
lemoldsnut is offline
firsttimeoldsowner
May 28th, 2015 06:43 AM
olds4life
December 25th, 2012 12:56 AM
theoldsrocket
June 1st, 2011 04:58 PM
flamez
March 22nd, 2010 01:57 PM
dman0712
January 5th, 2010 09:32 PM
Quick Reply: 79 olds 350 heads
