1970 Emissions connector, end of the snorkel
Does anyone still have one of these little hose connectors that fit into the hole at the end of a 1970 air cleaner? My plan is to 3D print one if I can get a good look at or measurements off one. I have already designed a piece that will work, but it would be nice to get it close to correct, if possible. Any pics from any and all angles would help!!
My 70 W-30 had the nipple, got lost over the years. Found another one on a 2bbl air cleaner. I'm curious if all 1970 charcoal vapor canisters are 3 port or just the Ca models. There are numbers on each piece, the nipple is plastic. Good luck.
The Vapor Control Canister was a mandatory option for vehicles delivered in California. An option for the canister did not appear on the Wholesale Car Order Form; therefore, no one could order the canister on a car being delivered outside California.
The 1970 canisters have three-port tops.
I'm interested in getting the air cleaner connector as well.
Based on the picture above, and knowing the size of the hole in the air cleaner, I submitted a drawing with estimated measurements to a friend who has a 3D printer. If anything comes from it, I'll sure let you all know. The clip doesn't seem to be a standard one that I can find - if anyone has an idea for that, let me know. Brake line clips are almost all 1/2", and that is too big for this piece. This looks to require about 3/8" on the inside. I found a usable clip on eBay that I'm going to try, but it would be nice to find something better.
I found a GM crankcase connector 1255-0625 that was used on the early 90's LT1 engines and ordered it. I have no idea if the size is correct yet, but it was the closest thing I could find for now. It might be an alternative if nothing else works...
Not to change the subject, but has anyone drilled or stamped out the hole in the snorkel? Need to make the emission fitting hole in a reproduction OAI air cleaner base without distorting the snorkel. Not a California car, but a '70 Rallye so needs the hole in the snorkel.
1970 Emissions Connector , end of snorkel
yes that is correct that tee came on all 1970 CA 4 speed cars . saw one at pick & pull Santa Fa springs it was a 4 speed 442 back 1980 but it crumbled in my hands .
BeenThere
March 1st, 2017 02:18 PM
BeenThere
January 21st, 2017 07:35 AM
