455 heads wanted
455 heads wanted
been looking for a set of heads for my 455 build. would prefer something ready to bolt on .not ready to go to the aluminums just yet .early 70's e heads would be great .got burned on the last set ended up being cracked .let me know .thanks, Jeff
shradezz i tried to send a couple pms in regards to them heads buy they dont seem to be getting through you can contact me at 518 727308 five. so we can discuss .442crazy i did get your pms and ill keep my options open with your heads
Pair of Mondello ported G heads with port matched Port-O-Sonic, Crane Gold rockers, & custom push rods, $1100.
I also have Comp Cams 42-601-5 cam with matching lifters, 234/249 @ .050 & .500/.486 $150
These have about 10,000 miles on them.
Rick
Rick
I'm not sure if you've found anything yet, but we can get you a set that are mag'd, cleaned, assembled and ready to roll. Stock, to fully ported and anywhere in between. It'd be advisable to at least have the heat risers filled. We could weld up the center divider too if you'd like. It really just depends on your needs. If you still need some, give us a call at 662-233-2301.
