Olds 455 main caps and bolts
Old June 16th, 2018, 02:51 PM
Rosco920's Avatar
I have a 74 455 block and I need the oem main caps and bolts. Let me know if anyone has any for sale.
Rosco920 is offline
Old June 16th, 2018, 07:57 PM
toymobile's Avatar
I have a set for 403, Are they the same??
Johnny
toymobile is offline
Old June 17th, 2018, 07:20 AM
Johnny
No. BBOs have 3" mains, gas SBOs have 2.5" mains.
joe_padavano is offline
Old June 17th, 2018, 07:53 AM
ROCKETMAN269V's Avatar
I have them. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
ROCKETMAN269V is online now
Old June 17th, 2018, 02:15 PM
Rosco920's Avatar
just sent
Rosco920 is offline
Old June 17th, 2018, 04:37 PM
Run to Rund's Avatar
If that doesn't work I have a 425 block (389244D) with small lifters and its original caps, which interchange with 455s. I would sell the block in the same price range as a set of caps. You could use the block with either crank, 425 or 455 (with slight grinding to clear the connecting rod nuts). Donnellyj@msn.com
Run to Rund is offline
Old June 19th, 2018, 07:49 AM
Rosco920's Avatar
Thanks guys. I'll just get a new block. Everyone, even the machine shops, are saying to get another block.
Rosco920 is offline
Old June 19th, 2018, 02:36 PM
I don't know if this means the machine shop isn't capable of performing a line bore, or has excessively high labor costs. I suspect there will be a lot of folks happy to take that old block off your hands for scrap value.
Old June 19th, 2018, 03:06 PM
Rosco920's Avatar
Well I don't know the cost because every machine shop I call tell me to get another block instead getting more caps. They act like it's hard or it'll never work.
Rosco920 is offline
Old June 19th, 2018, 03:09 PM
I'd be curious what, exactly, you asked them. I'd simply ask how much is a line bore on a 455 Olds. Main caps were NOT hand-fitted on the production line. They were machined to specific tolerances, then line bored.
Old June 19th, 2018, 04:18 PM
Olds production tolerances were much better than the chevy junk the machine shops are used to working on. You didn't have lots of Olds cams wearing out, because the lifter bores were crooked and the lifters wouldn't spin, like chevies.
Old June 19th, 2018, 05:01 PM
Rosco920's Avatar
So it sounds like you guys are telling me to keep the motor. I found some oem caps and bolts.
Rosco920 is offline
Old June 22nd, 2018, 11:27 PM
Cman7713's Avatar
Hey Rosco, I noticed you're in Blue Island. I'm down the street in Alsip. I had my sbo machine work and rebuild from Heartbreaker race engines in Oak Lawn. His name is Al. Decent guy and did a nice job on my engine. Might be worth a call to him.
Cman7713 is offline
Old June 23rd, 2018, 05:19 AM
Rosco920's Avatar
Thabks for the suggestion. I’ve called a lot of shops and they say to get another block or get new steel caps. They were saying that the caps are always shifting one way and a lot of times you’ll never get it to align properly. I’m going the new block route most likely. Thabks again for suggestion though. I’ve heard about that guy too. Had a buddy visit him for some engine work as well.
Rosco920 is offline
Bluerocket76
June 26th, 2019 05:48 PM
Oldzman71
December 4th, 2018 01:13 PM
Rosco920
June 17th, 2018 06:20 PM
70sx455
December 22nd, 2014 11:13 AM
72cuttys
August 30th, 2012 09:05 AM
Quick Reply: Olds 455 main caps and bolts
