Help needed for information on 1975 cutlass supreme window assembly
Old January 16th, 2018, 08:34 AM
Kodieking206's Avatar
so this is my 1975 cutlass supreme coupe I’ve owned it for about 3 years and I’ve been looking for a full window assembly. When the car got broke into and the previous owner took all the hard ware out of the window so I can’t get ahold of this main part
If anyone could help me find this part or knows of a place I can buy one that would help a lot thank you
Kodieking206 is offline
Old January 16th, 2018, 11:17 AM
Paladin31's Avatar
I have parted out a couple 73-77 cars, and I am sure I have what you need. If you could lay a tape measure or ruler/yardstick beside that I will let you know. And is it just that one piece pictured you're missing?
Brett
Paladin31 is offline
Old January 16th, 2018, 11:27 AM
Brett
If you have all the components I could use them but if not then the bar is the main focus
Old January 16th, 2018, 11:53 AM
Paladin31's Avatar
So basically you have the glass, and a door shell...and nothing else?
The guides, stops, brackets, regulator, lift arms are all missing?
Brett
Old January 16th, 2018, 01:27 PM
Brett
Yes and to be more specific I need for the drivers side I have the passenger side
Old January 16th, 2018, 04:26 PM
Paladin31's Avatar
I will get out and take inventory & let you know, will be a few days before I have time
Brett
Old January 16th, 2018, 06:55 PM
Ok thank you
Old January 16th, 2018, 07:30 PM
Paladin31's Avatar
No problem
Brett
Old January 27th, 2018, 03:08 PM
Paladin31's Avatar
Window comtrols
Thanks for the patience, here is what I believe you are looking for. , let me know which pieces you need from the group.
Brett
Old January 28th, 2018, 05:27 AM
Paladin31's Avatar
Pics
Old January 31st, 2018, 11:14 PM
if they are driver side then yes that looks like everything I need
Bradovich2
February 2nd, 2017 06:52 PM
ddcheese@msn.com
April 13th, 2016 09:02 AM
Hairy Olds
October 15th, 2013 11:14 AM
Hairy Olds
November 2nd, 2009 10:23 AM
Hairy Olds
October 31st, 2009 12:47 PM
Quick Reply: Help needed for information on 1975 cutlass supreme window assembly
