67 400 E Block
Old August 10th, 2017, 11:56 AM
GM MUSCLE's Avatar
67 400 E Block
Hi Guys,
I am in search of a 67 400 E Block for my 67 442. I recently took it apart due to a rod going through the pan, but in doing so I noticed the water ports or jackets have cracks in about three cylinders on one side and one on the other side. I purchased this car 4 years ago and finally finished putting everything back to stock. The interior, electrical wiring, the dash intake manifold and exhaust manifolds. The owner at the machine shop told me these cracks are because the previous owner let it freeze and caused the cracks. I know the car sat in a field in Missouri for years before I found it. Who knew right? Anyway the machine shop guy told me that it is repairable but it would cost me so much more to do and if I could get another block, it would be less expensive for me? Any thoughts on that? I have never seen this on a block before, is this the norm for Olds blocks or this can happen to any make? So if anyone knows of an engine for me, let me know. If I can't find another 400 I might go with a 425 Tornado engine.
Thanks,
Augie
GM MUSCLE is offline
Old August 10th, 2017, 12:25 PM
Oldsmaniac's Avatar
https://cnj.craigslist.org/pts/6212181382.html
Oldsmaniac is offline
Old August 10th, 2017, 01:15 PM
GM MUSCLE's Avatar
Thanks, Is this yours for sale?
Old August 10th, 2017, 01:55 PM
Oldsmaniac's Avatar
Not mine but I know him.
Old August 10th, 2017, 02:25 PM
71 & 72,now I want a 68
w-30dreamin's Avatar
I recently picked up a 400 E block with flat top pistons,rods and stick crank. It did have a spun bearing.
B heads
390390 intake
I haven't had time yet to have the parts magnafluxed or the crank checked to be sure it can be turned.
I would want to sell it all as a package deal.
Biggest issue would be shipping,I am in Indiana.
w-30dreamin is offline
Old August 10th, 2017, 03:36 PM
GM MUSCLE's Avatar
Well thanks, let me know I basically need the block itself, but if it is a package deal that's ok too. Shipping is the biggest headache... I understrand
Old August 11th, 2017, 06:47 AM
Run to Rund's Avatar
I have several in Vegas. Also a 66-425 short block, .842 lifters. If you don't find one closer, I could bring to Gettysburg next year at the OCA Nationals.
Run to Rund is offline
Old August 11th, 2017, 06:40 PM
65B01Delta's Avatar
I have a 67 E Block that is a Jasper rebuild some time ago, I pulled it out of a 67 442 Convertible, crank is drilled for manual trans also... It turns over, but would need rebuilt, it sat outside for 10 plus years in the car.. Not sure of the bore, probably been bored .30 over.. I never tore it down.. Engine is complete except carb, will sell as a short block. I have this in my garage for 10 plus years, time to let it go... Engine is located is Southeastern, Indiana 47025
65B01Delta is offline
Old August 12th, 2017, 05:25 AM
66trakpak's Avatar
I have what you need if your still looking. I'm located in central Long Island, close to the ferry.
66trakpak is offline
Old August 12th, 2017, 07:04 AM
GM MUSCLE's Avatar
Thanks for responding to my search. Is the block apart? See this is what I have an issue with. If I can not see the water jackets or ports around the cylinders it's just a gamble for me..These are a few pictures of what I found when I removed the heads of my engine..
cracks through the water ports...
Still ran strong, never overheated, but the upper radiator hose would get rock hard in less than 10 minutes of starting..
More cracks
Old August 12th, 2017, 10:04 AM
66trakpak's Avatar
Yes,I see what you mean. My block is stripped down. Just need to remove crank. My block has no cracks.
Old August 12th, 2017, 10:08 AM
66trakpak's Avatar
Pic
Old August 12th, 2017, 10:33 AM
GM MUSCLE's Avatar
Hey thanks for the pictures, looks good. How much do you want for the block?
Old August 12th, 2017, 11:55 AM
66trakpak's Avatar
Originally Posted by gm muscle
hey thanks for the pictures, looks good. How much do you want for the block?
475.00
Old August 12th, 2017, 11:58 AM
GM MUSCLE's Avatar
Great! How do we do this? I can drive down to you and pick it up. Just need an address and I can look it up.
Just have to figure out when is good for both of us. I work all day Sundays so any other day would be ok.
Augie
Old August 12th, 2017, 12:06 PM
66trakpak's Avatar
Sent PM
Old August 12th, 2017, 03:45 PM
GM MUSCLE's Avatar
I want to thank everyone who helped me track down my 400 E-Block for my 67 Olds 442. I did find the block that I needed!
Old August 12th, 2017, 07:32 PM
Kennybill's Avatar
That's great news for you. Having the correct engine really adds to the value when it comes to 442's. Good luck.
Kennybill is offline
Old August 13th, 2017, 03:35 PM
GM MUSCLE's Avatar
Thank You!
bspaulding
September 3rd, 2016 04:15 PM
TicTocTach
June 16th, 2015 04:03 PM
stonecad
February 11th, 2014 02:02 PM
ut442
March 9th, 2012 11:57 AM
chrisneu68olds
December 30th, 2011 10:17 AM
Quick Reply: 67 400 E Block
