1964 F-85/Cutlass top radiator plate and radiator
Are you keeping your car original? So do you need the radiator that has the hose connections for the 1964 only water pump? If so I have a used one that needs rodded and maybe re-cored. I'm swapping out the 1964 engine from my wagon. Let me know if you'd like to see pictures. I'll have to look and see if I've got an extra top plate, it was just a small bracket for 1964-65 compared to the later years. John
Well, I think you need to make that decision before buying a radiator. Unless you want to change the 1964 water pump to the newer more common design. I believe it would fit and that would give you the ability to go with the more common radiator and radiator hoses too.
John
P.S. I plan to go with the 350/TH350 on my wagon as I plan to use it as a daily driver.
John
John, I may be wrong, but I thought that the late water pump interfered with the timing mark on the '64 only engine. Am I incorrect? Thanks, Bob.
John
John
John
Streetrod -Few years ago I needed some back up lights for my 64 too and discovered that 67 Buick Skylark wagons are the same and scored these GM Guide backup lights still in the original box on E-bay. I think I used the Hollander to cross reference what fits what but not 100% sure.
Bee Saint Louis
July 5th, 2019 08:58 PM
Alex72cutty
April 21st, 2015 10:30 AM
tcarroll
December 26th, 2012 11:48 AM
60193W30
November 4th, 2012 05:41 PM
w-30dreamin
January 31st, 2010 03:20 PM
