Coolant overflow bottle needed..........
Old January 6th, 2016, 07:00 PM
limegreen71w30's Avatar
For a 1980 Cutlass with a V8. Original good or info on where a repop is obtainable. Any help is appreciated. Thanks
Ed
limegreen71w30 is offline
Old January 6th, 2016, 07:45 PM
If originality is not a problem, your local auto parts store has plastic tanks.
oldcutlass is offline
Old January 7th, 2016, 08:53 AM
Olds Fever
CRUZN 66's Avatar
Ed
I will check the part number requirements for the 1980 tank... But if you still have your tank, a part number is cast into the plastic... If you can let me know that part number, I will let you know for sure what I have available...
I most likely have an NOS one in my stock since I have at least 20 for the 81-88 A-G Body... I should also have the windshield washer tank as well if you need that....
CRUZN 66 is offline
Old January 7th, 2016, 11:10 AM
The Rocket Astronomer
lunaboy's Avatar
I have a used one Ed - removed from a 1979 years ago. pm me for details. if still looking
lunaboy is offline
Old January 11th, 2016, 04:56 AM
I think the part number is 14013343. Any body have anything?
Old January 11th, 2016, 08:54 AM
lunaboy's Avatar
dont think thats the casting no on the tank, mine is 459229 , it may be the p/n
lunaboy is offline
Old January 11th, 2016, 12:03 PM
Olds Fever
CRUZN 66's Avatar
The casting number & part number should be the same for coolant recovery tanks.... According to my part system, the correct part number used to be 459229, in 11/83 it was changed to 14013344, & in 7/85 it was changed again to 14085692.... Not sure why you show 14013343 unless they did decide to use a casting number instead of the actual part number, which makes sense since your number is only one digit difference from the actual part number back in 1983.... The good news, the part number 14085692, is still available from any GM dealer... GMPARTSDIRECT lists the part as available with a sale price of $15.79 (Normal list price is $23.50) plus shipping... If they list the part, it usually means that it is available from any GM dealer as well... Hopes this helps...
CRUZN 66 is offline
Old January 12th, 2016, 05:22 PM
lunaboy's Avatar
mine is a correct 459229 pre 83 and dirty so it must be worth 23.50
lunaboy is offline
Old January 13th, 2016, 08:19 AM
Olds Fever
CRUZN 66's Avatar
Very well may be.... Would all depend on what the OP is striving for - Functionality, Originality, or Show Quality....
CRUZN 66 is offline
REOLDS
January 18th, 2014 09:06 AM
71POWER
October 6th, 2012 08:29 AM
815Cutlass1972
June 2nd, 2011 04:53 PM
oldsonharmont
September 14th, 2010 05:27 AM
ilandtime
July 4th, 2008 03:01 PM
Quick Reply: Coolant overflow bottle needed..........
