vinyl and back window moldings
Boy do you ever! Not sure who did that hack job with aluminum (hope it wasn't you) but that looks terrible. One thing you'll have to do is fix the holes in the sheet metal before you install the new moldings, or it will start rusting from them - guaranteed.
The corners are re-popped:
But the rest of it you'll have to get from a donor car. John (2blu442), Eric (jensenracing77) or Scott (oldspackrat) can probably supply you with the parts you need. The alternative to the vinyl is to strip it entirely and have a solid color car. Depends on your vision for what the car will end up as. Good luck with your project.
Fusick Catalogue 45 Aug 1: Page 17
VT702S Vinyl Top Moldings 1970-72 2 Door H/T Cutlass Supreme with Vinyl Top 49.50 pr
From the photos shown it looks like that vinyl top is not factory.... The metal strips that are riveted to the sheet metal were most likely covered with matching vinyl strips... You will have to change those metal strips with the proper studs and clips to attach the original factory trim....
70Post
November 10th, 2022 09:30 AM
