Needed - '68 Toronado - Heater control valve & exh. donuts
1. Need a good used or new vacuum operated heater contol valve that mounts to the intake manifold. Non-Climate Control model.
2. Also need the exhaust donuts that have the steel sleeve in them. The current offerings do not have the original type steel sleeve, and do not hold up. The steel sleeve goes into the manifold a bit, and prevents them from getting loose or blown out.
Thanks, Jerry
Thanks, Jerry
Needed - '68 Toronado - Exhaust donuts
I have a box of NOS exhaust do-nuts, some with the metal sleeve. Do you know the size you need? Outside diameter of metal sleeve would be the best way to tell. Thanks, Bob.
Hi Bob,
Thanks for the reply. The outside diameter of the steel sleeve should be 2-3/8" plus or minus a bit. I got that by measuring the i.d. of a spare exhaust manifold.
LMK what you find.
Thanks, Jerry
LMK what you find.
Thanks, Jerry
Got 'em! If you need pics, e-mail me: drolds1@bellsouth.net. Thanks, Bob.
jensenracing77
March 19th, 2014 04:08 PM
