need 455 olds exhaust manifold and power steering pump
1972 olds 455 engine exhaust manifold help needed
i have a 1972 oldsmobile 455 engine and need exhaust manifolds for it..where can one pick a pair up for it...and can buicks or some other makes bolt on or just olds? ps i would go with headers but no space,,hence the manifolds...thanks
cobalt1967@live.com
cobalt1967@live.com
The 455, 400 & 350 OEM exhaust manifolds are being reproduced Fusick, OPG, Year One, etc...The WZs are the ones you want.
Fusick pn EM692WZ pg 63 in the Fusick catalog
The whole thing is a bit heavy & shipping costs are crazy, just like everything else, I'd guess shipping would be $20.00-$30.00?? If you want I can ship & get a total & let you know?
Thanks,
Scott
Thanks,
Scott
Cobalt I'm unaware of the frame setup in that car. You should probably get some pictures of the engine sitting on the mounts so we can see what you are up against. The standard car manifolds may not work depending on where the outlets are in relation the the frame.
With the 56 steering being behind the crossmember, you will probably have wo use W and Z manifolds. Even with those exiting in the extreme rear, you will probably have to offset the motor somewhat to the passenger side in order to clear the steering gearbox. You will also have to fab hydraulic lines for the setup. I'm assuming you have a factory power steering column and gearbox? Good Luck.
where the engine will sit
here is what a guy has done to his and i inclueded a pic of what my frame looks like...it will be minus the cross bar in the back...i think the manifold that go straight back and i can run a exhaust pipe to it.. and your right the engine has to be off set to the passengers side by 3mm to clear the steering box what ive been told
Keep in mind that used ones are going to be around 45 years old at this point and might not be any good. I have seen a couple sets where the divider between the center ports was rotten and they were basically junk.
I'm not saying you can't find them, just be aware that if you do you may not save any money on a good used set as these are central to a matching restoration.
If he doesn't take those manifolds I will. But he asked so let him decide first please.
If he passes email me direct thanks
Larry
lemoldsnut@aol.com
Larry
lemoldsnut@aol.com
slaughter442 i just sent ya a message
cobalt1967@live.com
cobalt1967@live.com
slaughter442 and oldspackrat i sent you both messages i would like to get ya paid this week and have ya send them too..thanks for your help...im getting pretty excited to finally get close to driving my 1956 oldsmobile...
So, depending on how you mounted the engine, you probably will NOT be able to use the W/Z manifolds from a 442. I'm guessing you may want a pair of the center dump "A" casting manifolds. These were originally used on the driver's side of 1965-67 full size cars but can be bolted to the passenger side as well. If your crossmember is forward and you have a steering box interference problem, this may be your only option. I'd suggest you think this out and look at photos of the various Olds manifolds before buying anything.
Larry
lemoldsnut@aol.com
Larry
lemoldsnut@aol.com
#31
384785 "A" exhaust manifolds
Oldssupreme
Brakes/Hydraulic Systems
August 1st, 2014 03:49 AM
nicks1966
January 12th, 2014 01:46 PM
JPMDaddy
July 8th, 2013 08:06 AM
