Jetaway Trans. Slip Yoke
Wanted - Jetaway Transmission slip yoke (1957-1960 any year). Needed to put in end of transmission to prevent oil leakage when pulling engine/trans. assembly.
Send me a PM if you have a yoke available. Thank you.
Apologies If I am wrong. I certainly don't want to contribute to truth decay.
I assumed that the Jet-away trans was an early 60's unit that shared the same
size output shaft as the turbo 350. If so, I have an extra Gary.
Is this the same as a cast iron power glide? I have one of these. looks new.
Unfortunately same name different transmission. The early jet-away was a 4 speed the latter one was a 2 speed, completely different transmission.... I don't know if the yokes are the same or not nothing else exchanges though.... Tedd
If the Jetaway and TH-350 yokes are the same diameter, a TH-350 yoke still won't work because I believe they are 27 spline. My dad says the Jetaway yokes are 32 spline.
I'm into 73-77 Cutlass, so I'm not super familiar with the "early model" stuff! Kind of an inside joke - he calls my 73 and 74's "late model."
Thanks. I've got a spare TH-350 yoke. Even if they are the same diameter, I don't think it will work. I think TH-350 yokes are 27 spline and Jetaways are 32 spline.
I have plastic plugs for turbo 400's, so go to a tranny shop and ask for plastic plug that might fit your trans. Take ID and OD info with you. Just remembered that I picked up these plugs at a plant that rebuilds transmissions in T.O.
Last edited by Yellowstatue; November 2nd, 2016 at 06:08 PM. Reason: Info explosion.
jeffs 89 cutlass salon
October 19th, 2007 08:42 AM
