Headliner Clips - '68 442/Cutlass
I'm replacing the headliner in a '68 442 Holiday Cp.
I'm needing 3 of the clips which run along the center of the roof, parallel to the length of the car. And, I'm needing 3 of the clips which hold the dome light wires and are perpendicular to the car's length.
I've ordered/received replacement clips, but found they do not hold the headliner wire/fabric snugly.
Thus, I'd like to get originals if anyone has them.
A photo of both types of clips is attached. The first style noted above is on the right.
Thanks,
Tom
Thanks,
Tom
Hey Tom I.believe I can help you out. 210-264-3158 shoot me a text and when I get home ill take some pictures of the ones I have. Still have them on the car and just took off the headliner with the dome light.
While we're at it I'm needing to reinstall the long metal trim pieces which go on the outer edges of the headliner and run from the A pillars to past the qtr windows. Do the tops of the vertical A pillar pads go on the outside or inside of the trim pieces? Someone else removed mine so I'm not certain. Thanks.
ros6872
August 30th, 2012 09:34 AM
Kidcutty
December 5th, 2010 09:04 PM
