67 Cutlass speedometer
I had a '73 Custom Cruiser that did the same thing. The speed indicator needle would wave around a bit and make whirring noises when the car was moving and the weather was cold. After driving a few miles or when the weather was warmer, things would settle down. The odometer always worked, and I just assumed it was correctly adding a mile for every mile traveled, but I never actually checked it.
You can easily repair the speedometer yourself. Google "55-72 speedometer repair" and click on the one that has Ecklers Classic Chevy for detailed instructions how to disassemble and lube your speedometer. This applies to all GM speedos. If you send it off to be repaired, this is what the rebuilders will do.
Good Luck...
Good Luck...
Good Luck...
Good Luck...
This is another good tutorial on speedos
70 ctls
December 8th, 2012 11:33 PM
ros6872
February 8th, 2010 08:35 AM
