1962 Starfire Exhaust Hangers
As far as I know nobody re-produces hangers for '60's "B" bodies .
But if you have old and crusty ones they can be re-stored like this ;
Before ;
And after;
I drilled the rivits to weaken them and drove them out with a punch .
Then the metal pieces were bead blasted and painted ;
The rubber parts were cut from some industrial belt material . And it was all bolted together .
Before ;
And after;
I'll look....are you replacing the exhaust? Here's what I did on my 62' Starfire. I drilled the rubber straps off of the brackets that attach to the frame. I then blasted and painted the brackets and bolted these Edward's hangars to the brackets then reinstalled the brackets on the frame. When I put my new exhaust in we'll weld the hangar to the pipe and have a much neater install. Go to Summit website and type in Edward's exhaust hangars 36516.
Dennis
Dennis
Yes, new exhaust system, using 1964 Starfire mufflers, should hang in the same location. I will check out those hangers.... my car does have the original hangers, but the rubbers are shot.... thanks for the info!
Dennis
Dennis
That's good and $8 for the ride on USPS. Send a check or money order and then they'll go in the mail. Also your address. Here's my address.
Dennis Harmon
20 Cessna Ln
Stockbridge, Ga.
30281
Dennis Harmon
20 Cessna Ln
Stockbridge, Ga.
30281
Vinny, let's talk by private email. I have your tracking number.
dennis_30281@yahoo.com
65OldsDelta88SuperRocket
December 10th, 2011 01:14 AM
