SBO adapter Plates for seprentine belt set up with mechanical fuel pump
$200 plus shipping.
It is best to reach me at ExtremeSuprememachine@gmail.com
You will receive three pieces,an adapter plate for the driver's side,passenger side,and the lower support bracket for the driver's side.
You need to use the crank pulley from a 302 Ford, the reverse rotation water pump from a diesel V6 Olds engine.
I'll also throw in the necessary flat head screws needed.
Here is the thread from ROP that has a lot of good info on the swap, This thread was for the BBO adapter plates. The parts needed and install of these would be basically the same.
https://www.tapatalk.com/groups/real...ates-t252.html
