1967 Olds 98 88 Front Disc Brake Rotors
Hi All
I've got a pair of front disc brake rotors from a 1967 Delta 88. These are the two piece rotors that were factory in this application. They are in good condition and could be run without turning. I checked them with my harbor freight caliper and I believe they still have about 0.015 that could be turned before they reach the minimum thickness. I did run over them with some Emory cloth to clean the stains off from where the pads had sat. I wasn't completely successful, but there are no pits or grooves in the rotors. I'd like $100 each plus shipping from Medford Oregon. I also have the 4 piston calipers from this car, but haven't located them yet... I put them in a real safe place! When I do find them I'll be asking $40 each as cores for rebuilding. I do have a complete changeover setup from a 1970 and visually these rotors look alike. I believe the hub is a little longer on the 1970, so I don't know if these would interchange or not. Let me know if you have any questions or would like to see any other views. John
northwoodsgr
Brakes/Hydraulic Systems
July 26th, 2023 12:01 PM
2blu442
January 15th, 2019 03:27 PM
